Roto-Fab
Old 02-23-2023, 11:01 PM   #1
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
2010 2SS/RS/M6 clutch fluid.
I have just over 50K miles and I can feel a slight slip in the clutch. I read online that I should change the brake fluid with new. Is there anything special I should use or just regular DOT4 brake fluid. Is there a better product available. Has changing the fluid had any effect on clutch slip?
OHIOSS is offline   Reply With Quote
Old 02-24-2023, 05:42 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
There are lots of variations of brake fluid from generic parts store brand to Castrol SRF and Motul 660. They range widely in price. If you don't track it, you probably won't notice a difference in their performance.
Changing the fluid won't affect a slipping clutch, but it might make the pedal function better.
Old 02-24-2023, 11:42 AM   #3
camguynj
camguynj's Avatar
What he ^^^^ said. ALL brake fluid is synthetic so any dot4 will do. I use the cheapest when I flush my remote reservoir every few mos (you should consider installing one) but dirty fluid does NOT cause clutch slippage, it just effects/causes a sticky pedal return.
