Old 03-13-2015, 10:55 AM   #1
jesse454545
Drives: 2011 CAMARO 2SS/RS
Red 12V Wire Dead
I have been trying to install an aftermarket radio and i wired everything right so i was wondering why the aftermarket head unit was not powering on. I Decided to take a multimeter to the yellow and red wire to see if it was reading 12V and the yellow constant 12v wire was good but when i tested the red 12v AAC wire it was dead. I checked the fuses in the trunk and under the hood and nothing seemed to be burned out. Is there something im messing or something that i should re check? Help is greatly appreciated right now.
jesse454545 is offline   Reply With Quote
Old 03-13-2015, 12:34 PM   #2
baum
Drives: 2013 1LS, 2013 Ram 1500
What dash kit are you using?
the module on the dash kit could be bad. there isnt an actual ignition lead at the radio. with the factory radio the ignition lead is through the canbus system. the module converts the canbus signal into a switched signal
baum is offline   Reply With Quote
Old 03-13-2015, 12:45 PM   #3
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
this. It sounds like a bad module in the dash kit, especially if your wiring checks out. Don't forget to check the fuse on the radio itself, if applicable.
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 03-13-2015, 03:15 PM   #4
jesse454545
I am using the metra kit and I have checked the Fuze on the radio and I know for sure the radio works since it comes on when I plug it into the 12 volt constant power. Is there a way I can run the red 12v wire from the aftermarket radio into a wire that's on the car that is only supplied 12v when turning the key?
Old 03-13-2015, 03:17 PM   #5
jesse454545
And as for the metra kit everything works fine with it. It lights up I can turn on the A/C, heater, change the color but it's just when I connect the aftermarket radio to the stock harness that's when the issue comes.
Old 03-13-2015, 07:20 PM   #6
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
In this thread you started you stated that you did not have the wire harness. Do have the harness now?
Caddy
Caddyroger is offline   Reply With Quote
Old 03-14-2015, 10:50 PM   #7
jesse454545
I have a harness but everyone is saying it's the right harness since I have the scorch harness. But at the same time I am not getting 12v from the red wire on the stock harness.
Old 03-15-2015, 01:55 PM   #8
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
I'll say it again....if you are trying to use the Scosche harness with the Metra kit IT WILL NOT WORK. To bypass the Metra kit's ignition turn on by using another ignition circuit is just the wrong thing to do.
Do you have the module (black box) connected in the Metra kit? If not, I can't understand how anything is working, as this is the box that converts the CAN bus signals for the radio and the heat/AC.
jeffa is offline   Reply With Quote
aftermarket, harness, radio, red, yellow
