Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros
Old 03-24-2016, 06:35 PM   #1
moserbe
moserbe's Avatar
Drives: 2012 Camaro SS
Window Roller Channel 16625875
Roller on driver side window channel is bad and I can't find a replacement part anywhere. I'm sure that others have had to deal with this too. What have you done to correct this issue?
moserbe is offline   Reply With Quote
Old 03-24-2016, 08:26 PM   #2
MrCool
MrCool's Avatar
Drives: '95 Z28
Is this the part rived onto the glass, or is it one of those tracks inside the door?
1995 LT1 Z28, "Bright Teal Metallic", Stock
MrCool is offline   Reply With Quote
Old 03-24-2016, 08:34 PM   #3
MrCool
MrCool's Avatar
Drives: '95 Z28
Nevermind, it's one of the tracks. I think you should be able to replace it easier than replacing the actual glass. I've had to replace the glass twice, and it's a major pain.
EDIT: By sliding the glass forward and back and towards teh car and away from the car you should be able to manuver the glass out of the track and replace it with a new one. Not sure if this helps you, but that's what I did.
Old 03-25-2016, 02:57 AM   #4
moserbe
moserbe's Avatar
Thanks for your reply. If's the one riveted to the window with the roller. The roller is shot on mine.
Old 03-25-2016, 04:11 AM   #5
MrCool
MrCool's Avatar
Drives: '95 Z28
That's exactly what happened to mine. It's that plastic roller right? I replaced my whole window just for that stupid roller. There has to be an easier way though, because it's crazy that we have to replace the whole window just for a stupid plastic wheel.
Old 03-25-2016, 04:14 AM   #6
MrCool
MrCool's Avatar
Drives: '95 Z28
I know Autozone sells these, but I couldn't figure out how to put them on the window other than welding it on:
Dorman/Window Regulator Roller
Old 03-25-2016, 05:27 PM   #7
moserbe
moserbe's Avatar
I found a good used one today and it's being UPS'd to me. Took a lot of research and I got lucky.
