12-14-2016, 08:11 PM | #1 |
Dyno Show Queen LOL
2010 TT 2SS RS Rally Yellow
29k
78k on the car less than 5k on the forged motor. Professionally built 10:1 compression 416 LS3 by LME Callies rods and crank Wiesco forged piston gas ported LS3 GM ported heads BTR Stage 4 turbo cam ARP Head Stud upgrade ARP fastness Meiling HV oil pump ATI fluid damper MM catch can ID 850s Livernois dual pump ADM dual pump control module Ceramic coated stock manifolds AGP TT Kit ceramic bearing upgrade EFR series larger intercooler Fuel 93 octane no meth 10 psi springs makes about 8 or 9psi and 700 rwhp meth and a boosta pump will get you past 800 easy but I wanted to do the right thing and,do a fore or squash BMR solid motor mounts Monster tripple clutch with metal sleeve upgrade Complete 1le 2015 Subframe so it has the newer F5e rear, 3.91 gears, 1le Axles, 1le shocks, 1le swaybar BMR subframe bushings Spohn spherical toe rods BMR upper control bushings BMR lower control arms BMR Lower control arm bushings Front BMR inserts control Arms Front 1le sway bar Front BMR endlinks MSG shifter MMR Z28 replicas ZL1 front end upgrade OEM ZL1 Hood OEM Oracle plasma blue halos ZTW Spoiler new in box not on car ACS rocker panels Schoosce face unit Pioneer touch screen Some yellow parts painted inside not to over done Maintenance since rebuild 8 mos ago Redline in rear end and gm additive 20/50w mobile 1 Redline transmission fluid Needed to complete fore system to make 1100 rwhp Better Axles or Zl1 rear end Driveshaft upgrade Fastest time 13.13 @ 131 spinning all the way I never risked it or wanted to hurt my car by running slicks. I don't really need to sell it just but I do want another 6th gen... Driver seat shows wear Rock chip on top of front fascia Vynil gill marks starting to peal Thats all that sticks out..
12-14-2016, 08:55 PM | #2 |
Dyno Show Queen LOL
29k I forgot to post..
12-30-2016, 07:58 PM | #3 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Bump it up for a LME Forged motor and all
2017 Grand Sport, Borla X Pipe.....Enough Said
03-07-2017, 12:34 PM | #4 |
Dyno Show Queen LOL
Bueller Bueller... Anyone Anyone..
