03-13-2010, 03:33 PM | #1 |
Old HP ratings vs new
Its been talked about before how HP ratings were calculated differently "back in the day". I was just curious how they were calculated compared to now? I mean if a camaro in 69 had 375 horse what would that make today,what would ours make then, also are the torque ratings measured differently? Just curious THanks
Loving this car!
03-13-2010, 03:42 PM | #2 |
Drives: CHEV TAHOE CHEV IMPALA 69' COUGAR Join Date: Nov 2009
''Back in the day'' horsepower and torque ratings were measured in SAE( society of automobile engineers)gross.meaning the power was calculated at the flywheel. Currrently, we measure SAE net ratings that account for the losses that occur from the transmission and driveline.If the two numbers are the same the net rated vehicle has more horsepower.
03-13-2010, 04:20 PM | #3 |
Drives: 1976 camaro Join Date: Jul 2009
eh i tend to disagree with that
most cars are rated at 426 horse and are dynoing at 350 back then it was the same way |
03-13-2010, 04:22 PM | #4 | |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Agree ... The LS3 426 Hp is gross at the crank aka flywheel ...
03-13-2010, 04:31 PM | #5 | |
Drives: 2003 Cobra Convertible Join Date: Feb 2009
03-13-2010, 04:35 PM | #6 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
They are not the same. Old numbers were measured not calculated at the flywheel as they are today but back the they had no accessories. So no ac compressor no alternator no power steering pump.
Today's engines are measured as they would be installed in the car, the V6 in your Camaro is making nearly the same hp as the old V8s
03-13-2010, 05:20 PM | #7 | |
Drives: 2019 Dodge Daytona R/T Join Date: Feb 2009
Quote of the year, from 6.1hemi:
"I just wanted to type some junk cause I am having some beers and I really like cars." |
03-13-2010, 06:06 PM | #8 | |
Loving this car!
03-13-2010, 06:12 PM | #9 |
auto's nowaday's are about as efficient as the smaller/weaker transmissions of yesteryear, and much more efficient than the stronger automatics of the past.
03-13-2010, 06:55 PM | #10 |
Drives: 2010 2SS RS L99 Join Date: Oct 2008
in 1970 my camaro was rated at 200HP, in 1971 the same engine was 155HP.
03-13-2010, 09:35 PM | #11 |
The power lost through the transmission was never taken into account back then or today, so it has no effect on factory hp ratings. Factory hp ratings have always been measured at the flywheel on an engine dyno.
03-13-2010, 09:36 PM | #12 |
Drives: '19 Stingray '22 MB GLC 300 Join Date: Jan 2009
Stolen from the internet....
Before 1972, most American engines were rated under the methodology laid out in Society of American Engineers (SAE) standards J245 and J1995, which calculated the output of a 'bare' engine on a test stand with no accessories, optimal ignition timing, free-flowing exhaust headers (no mufflers), with a correction factor for standard atmospheric conditions. Starting in 1971, manufacturers began to lower compression ratios and de-tune their engines to prepare for the advent of unleaded gasoline. Both the early emission-control systems (air-injection pumps, exhaust gas recirculation) and the reduced compression ratios made engines perceptibly less powerful, whether those losses were reflected in the gross power ratings or not. Faced with this reality, along with the pressures of the safety and environmental lobby, domestic manufacturers decided it was time to abandon the gross rating system. In its place they adopted the SAE net rating methodology, described by SAE standard J1349. "Net" horsepower ratings are still made with the engine on a test stand, but with stock ignition timing, carburetion, exhaust, and accessories -- in short, a closer approximation of how much power an engine produces as actually installed in the car. (SAE net horespower does NOT, contrary to some assumptions, measure horsepower at the drive wheels; both gross and net ratings are at the flywheel, and don't reflect power losses in the drivetrain.)
"Ever since we got the Camaro, everything seems better"
-My 6 year old daughter |
03-14-2010, 03:33 PM | #13 |
Wheel Guy
All that matters to me is how much of that power is hitting the street.
Similar Threads | ||||
Octane Ratings? | Icefsh | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 12 | 03-10-2015 05:10 AM |
Cruze: Crash Test ratings in Europe | Mr. Wyndham | General Automotive + Other Cars Discussion | 20 | 11-29-2009 03:11 AM |
2010 Camaro Crash Test results - Full (almost) | Vizon | 5th Gen Camaro SS LS LT General Discussions | 390 | 08-30-2009 12:58 PM |
power ratings? | mp11 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 30 | 02-14-2009 03:04 PM |
Bob Lutz on JD Power Durability ratings | Mr. Wyndham | General Automotive + Other Cars Discussion | 2 | 08-31-2007 11:11 PM |
