Roto-Fab
Old 10-25-2018, 06:55 PM   #1
ca_z28
Drives: 2014 Z/28
Track Day Tire Pressures
What tire pressures are people running on track days. I have gone from 32 cold down to 26 and don't seem to get consistent results. My fastest day was the first run in the morning at 32 cold. On another day I ran 32 hot and didn't go very fast.
ca_z28 is offline   Reply With Quote
Old 10-26-2018, 05:58 AM   #2
j o n
j o n's Avatar
Drives: 2015 Z/28 #0058
GM was saying to start session at 28 psi and once Trofeos get to 32 psi, max grip engaged.... tires are at temp
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's
- '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony
Sold:
- '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's
https://www.instagram.com/__jon__athan__/
j o n is offline   Reply With Quote
Old 10-26-2018, 07:23 AM   #3
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Drives: 2016 Camaro 2SS
A buddy of mine on this forum recommended I put my Hankooks down to 25 psi. I noticed results.
Old 10-26-2018, 03:27 PM   #4
quickdrraw
quickdrraw's Avatar
Drives: 2015 Z/28
I run my rears tires about 1-2PSI lower (hot temp) than my front tires. This seems to balance the oversteer/understeer problem better. If you have stock camber plates and can't get enough negative camber, or want better turn in, this may help. Check for side wall roll over on each session and adjust accordingly.
2015 Camaro Z/28 Black
Sold:
2010 Camaro 1SS/RS
quickdrraw is offline   Reply With Quote
