Old 07-05-2011, 05:50 PM   #1
DoggyB22
DoggyB22's Avatar
Drives: 2001 Camaro Z28, 2016 Camaro SS
Arrow Track and Dyno Tested: 750hp SLP ZL1 Camaro Convertible
Featured on Camaro5 HOMEPAGE.
Not bad at all..... Going that this is a convertible. I'm sure we would expect better times with a hard top. Cant wait for Chevy to release the ZL1 times.
That sound is just
Track Tested: 2011 SLP ZL1 Camaro Convertible
Dyno Tested: 2011 SLP ZL1 Camaro Convertible
When we posted our Track Tested results of the 2011 SLP ZL1 Camaro Convertible, a few of you cried foul. The trap speed, commenters opined, was too low to support the claim of 750 horsepower. Put it on the dyno, came the cries.
Ask and you shall receive. The result is across the jump.
Let's recap with what we're dealing. For their ZL1 package, the power brokers at SLP work up an LS7 block with a forged chromoly crank, a hotter cam, beefier rods and pistons, LS3 heads massaged with new valvetrain hardware, and then top the whole works with a TVS 2300 blower. They touch almost every other engine component, too, replacing the bearings, timing chain, oil pump, pushrods and head studs with racier stuff.
SLP then pop in a stouter clutch, a lighter flywheel, proper tubular headers and a big-bore exhaust. The result of all this work is 750 horsepower at the flywheel and a rip-snorting exhaust note.
In the confines of MD Automotive's Dynojet chassis dyno bay, the sound of seven liters of uncorked supercharged pushord V8 ricochets off the walls, positively pummeling your senses -- this is a convertible, after all, and so we just had to put the top down while on the dyno. The TVS blower is silent, too. You mostly hear exhaust, and lots of it.
What we measured can be seen below:
Its fat dome of a torque curve peaks at 610 lb-ft at 4200 rpm, and peak power of 617 horsepower arrives right at the fuel cut. That little blip in power right at the fuel cut was not repeatable, so the peak is realistically closer to 610 hp at the wheels.
If you're a fixed-percentage-driveline-loss kind of guy, it will help to get your bearings around what a stock Camaro SS puts to the ground. In our testing on this dyno, a stock Camaro SS loses to the driveline 13% of its total flywheel power. Most production RWD, normally aspirated cars exhibit roughly 10% reduction from flywheel to wheels on this particular dyno, so 13% is on the conservative end of the range. Apply this value to the SLP ZL1 and it appears to be shy of its 750 hp claim by a bit.
A big factor is playing into this, namely geography. SLP are based in Michigan. Michigan and much of the rest of this great nation enjoy the fruits of 93 (and in many cases 94) octane fuel. For a forced induction engine, octane does to power what catnip does to your tabby -- it really perks things up.
Now consider that we do all of our testing in California, and that California is not in Michigan, which means a) we don't point to our palms when describing our hometowns, and b) the highest octane premium fuel that's widely available is shitty 91 octane. Yes, 91 octane is completely lame.
You know where I'm going with this. SLP developed their 750-hp calibration on midwest fuel and not 91 octane. On the plus side, I didn't hear a single ping while on the dyno, which means their knock detection works very well. The downside is that the car simply won't make the same power on 91 as it does on 93 octane. SLP doesn't sell the ZL1 to California residents anyway, thanks to the draconian (and expensive) hoops that CARB requires companies to go through in order to do so. However, the CARB-free states of Arizona and Nevada also max out at 91 octane.
Thing is, SLP are their own competition. A while back we tested on this very dyno a Camaro equipped with the company's ZL575 package, which claims 575 hp at the flywheel. The ZL575 put down 558 horsepower and 513 lb-ft to the wheels on 91 octane, and it ran a 116.8 mph trap speed to the ZL1 'vert's 117.2. True, the ZL575 is lighter than the ZL1 (by about 240 lb) and has better aero, but the comparison of it to the ZL1 shows that making even more power on 91 octane quickly becomes a losing proposition.
But hey, the ZL1 still manages to out-sauce a freakin' 911 GT2 RS, which is no mean feat in its own right. Still, our advice for those perusing the SLP offerings is to stick with the ZL575 package.
MORE SLP ZL1 CONVERTIBLE PICS:
01' Camaro Z28
H/C/I & a 200 shot 450 rwhp & 420 lbtq NA. TBD on spray
16' Camaro SS
LME 416, cammed, high ram intake, ported LT1 heads, stalled. 600 rwhp 550 lbtq
DoggyB22 is offline   Reply With Quote
Old 07-05-2011, 10:06 PM   #2
lewylew
lewylew's Avatar
Drives: 2010 ZL550& 2021 C8 Z51
That car should run mid to low 11 second 1/4 mile.
lewylew is offline   Reply With Quote
Old 07-06-2011, 05:19 AM   #3
35th02ss
35th02ss's Avatar
Drives: 02 SS
SLP's car is a ZL1... Might not be from GM but still a ZL1 non the less.....
35th02ss is offline   Reply With Quote
Old 07-06-2011, 06:22 AM   #4
snizzle
Recalled user
snizzle's Avatar
This is why I was hoping GM would go with another name, lol
Old 07-06-2011, 09:31 AM   #5
CamaroPhotos
CamaroPhotos's Avatar
Drives: 2010 ABM 1LT/RS; 1965 Chevy Impala
Snapped this on I-96 near the Milford, MI Proving Grounds this morning (sorry about the poor pic quality from my cell phone; not to mention a dirty windshield). I'm guessing these are SLP ZL's since there was no noticeable badging on them yet other than the "ZL" center caps on the rims. The 2 at the front of the trailer are convertibles. All had the distinct exhaust 'cans' and hood to accompany the center caps.
CamaroPhotos is offline   Reply With Quote
Old 07-06-2011, 09:36 AM   #6
GoldenBear
Bear Backer
GoldenBear's Avatar
Drives: 69 Camaro Z/28, 69 Corvette Conv
Technically, SLP's car is an SS that gets modified (at the cost of $80,000 on top of the price an an SS) and then is re-badged and marketed as a ZL1.
Current Chevrolets: 1969 Camaro Z/28 -- 1969 427/390 Corvette Convertible -- 1970 350/300 Corvette Convertible -- 2013 Camaro ZL1 Convertible -- CRT / Exposed CF Weave Hood Insert / Suede Package / Polished Wheels / MN6
GoldenBear is offline   Reply With Quote
Old 07-08-2011, 08:23 AM   #7
detltu
detltu's Avatar
Drives: 1992 Z28 1LE; 2015 Zl1
Cool video. Thanks for posting.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x
1991 Camaro Z28-
1991 Camaro Z28 1LE-
1992 Camaro Z28 1LE- 25th anniversary
2015 Camaro ZL1
detltu is offline   Reply With Quote
Old 07-08-2011, 08:41 AM   #8
Z4me
Z4me's Avatar
Drives: 2013 ZL1 IOM Vin #169
Companies such as SLP have paved the way that Thier
is indeed a market place for such a car as the GM
version of the ZL1. For that alone I give a BIG
THANK YOU!
<img src=http://www.camaro5.com/forums/image.php?type=sigpic&userid=36987&dateline=1334886195 border=0 alt= />
Z4me is offline   Reply With Quote
Old 07-08-2011, 08:45 AM   #9
PeeBee
PeeBee's Avatar
Drives: "Bee" ZL585, Dark Blue Suburban.
Three ZL585's...
That's the one from SLP to compare with the "real" ZL1.
PeeBee is offline   Reply With Quote
Old 07-08-2011, 08:48 AM   #10
Shurenuff
Shurenuff's Avatar
Drives: 2002 Nissan Altima
I don't understand the performance numbers either.
Shurenuff is offline   Reply With Quote
Old 07-08-2011, 08:57 AM   #11
GoldenBear
Bear Backer
GoldenBear's Avatar
Originally Posted by PeeBee View Post
Three ZL585's...
Tuner cars certainly have their place, but I don't think it makes sense to make apple to oranges comparisons between tuner cars and factory vehicles. I think comparing tuner cars to other tuner cars (e.g., Hennessey to SLP to Lingenfelter) is a more useful exercise, as is comparing factory cars to other factory cars (e.g., ZL1 to GT500).
Old 07-14-2011, 11:21 AM   #12
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
The Car is ridiculously priced!!
GEEo is offline   Reply With Quote
Old 07-14-2011, 11:38 AM   #13
MohawksIOSS
SoCal HT5 (COTW:12/26/11)
MohawksIOSS's Avatar
Drives: 2011 Inferno Orange 2SS
Hmm wonder what this will cost, i know what it cost me to make those numbers in my SS :-)
3/2/15 (787HP/822TQ @13psi)
MohawksIOSS is offline   Reply With Quote
Old 07-14-2011, 11:52 AM   #14
Black5thgen
Drives: 2007 C6
It takes a forged LS7 and a TVS2300 to get to Whipple LS3 numbers?? I am very impressed with the package, I think it looks awesome. However I am really let down by the HP and ET numbers.
Black5thgen is offline   Reply With Quote
ZL1 / CTS-V Brakes JusticePete Suspension / Brakes / Chassis 584 10-14-2021 09:33 AM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 05:56 PM
EVERYBODY POST YOUR DYNO NUMBERS!(sticky request) KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 365 07-19-2020 11:32 PM
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
Poll -- Camaro vs Mustang Supercar Shootout JusticePete Suspension / Brakes / Chassis 105 10-09-2013 02:18 PM
