dave@hennessey
Old 08-26-2016, 11:10 AM   #1
SSlacker
SSlacker's Avatar
Drives: 2012 2SS/RS
6L80 Trans failure
Lethal Racing installed nightfury cam and other power mods about 3 years ago,also installed 3400 stall in factory trans.
About a year ago the trans clutches burnt up, Certified Transmission installed a "Road Ripper 2000", which just failed as well.
They are now telling me they are going to refund money and send me a core, but they didn't want anything to do with it.
Now someone is telling me to convert to a 4L60 trans, WTF...
Does anyone have a suggestion?
In Houston, TX area.
2012 SS/RS Lethal Racing Night Fury Cam LS3 Conversion LR Spec Ported Heads Stainless Works Headers 1 7/8 Off road Cats Yank 3400 Stall Trans oil cooler w/fan Custom tuning
CAI w/ Scoop
SSlacker is offline   Reply With Quote
Old 08-26-2016, 03:29 PM   #2
bct10985
4L80
Old 08-26-2016, 05:13 PM   #3
flyer08
Drives: 2010 2SS/RS
4l80 will handle your power easy
flyer08 is offline   Reply With Quote
Old 08-29-2016, 03:00 PM   #4
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
I have a th400 in mine
camarosspower is offline   Reply With Quote
Old 08-30-2016, 12:22 PM   #5
Tech@B&MRacing
Tech@B&MRacing's Avatar
Drives: 2016 Camaro SS
What kind of power are you putting out? What is failing on the previous transmissions? Was it the same thing both times? Could excess heat be a factor?
Tech@B&MRacing is offline   Reply With Quote
Old 09-11-2016, 08:11 AM   #6
SSlacker
SSlacker's Avatar
Drives: 2012 2SS/RS
Third and Fourth gear clutch failure.
Yes, same failure both times.
Still in shop, don't know what to do next...
CAI w/ Scoop
Old 09-11-2016, 09:25 AM   #7
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
Get your 6l80 built right.
briancamaross is offline   Reply With Quote
Old 09-11-2016, 05:41 PM   #8
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
4L80 AND BE DONE WITH IT.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 09-11-2016, 07:21 PM   #9
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
Contact Circle D
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 09-11-2016, 08:33 PM   #10
DOC52
THE U
DOC52's Avatar
Drives: Camaro 1SS/RS
4l80 or th400, thats what I would do if I blew mine up.
DOC52 is offline   Reply With Quote
Old 09-12-2016, 04:52 PM   #11
DarrinSmartL99
Drives: 2010 Camaro SS/2SS
GPI does rebuild like Rick Crawford using stock clutches and adding additional clutch to packs. Requires some maching, but holds up very well. Aftermarket clutches do not last.
DarrinSmartL99 is offline   Reply With Quote
Old 09-12-2016, 05:12 PM   #12
AGP Turbo
Drives: All things Turbocharged
So you are likely under 500whp right? The gearing in the 6L80 is totally on your side and a 4L80 or TH400 is likely going to make you slower. The key thing is the tune, not the build. A stock 6L80 tuned right would be fine in your car. Tune Tune Tune
AGP Turbo is offline   Reply With Quote
Old 09-12-2016, 08:14 PM   #13
WhiteSS4
Drives: Camaro SS
Hit up futral in Baton Rouge. Bit of a drive but they did good work with my 6l80
WhiteSS4 is offline   Reply With Quote
Old 09-14-2016, 08:09 AM   #14
Mr. Nasty
Mr. Nasty's Avatar
Slower yes with the 3.27 gear off the line. But not with the rite rear gear.
With 633rwhp I do well with the 4L.
