08-27-2016, 03:00 PM | #15 |
Drives: camaro ss\rs Join Date: Jun 2014
ooh ****,this stuff scare me the hell out of
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
08-27-2016, 03:52 PM | #16 |
Drives: 2010 2SS/RS & 2007 2500HD D-Max Join Date: Dec 2014
No kidding!! I'd like to hear more from reputable builders!
2010 Summit white SS/RS, Manzo full exhaust w/2" primaries, Roto-Fab intake, FE4 conversion, JRI Coilovers built by Ult_Performance w/hypercoils, BMR sway, BMR trailing arms, UMI toe links, solid sub-frame bushings, upper control arm bushings, radius inserts, caster locks, Taylor wires, BTR spec'd cam, tuned by ECS, various little lighting mods, ebay SLP splitter, Heritage grille, ZL1 rockers, Apex 19x11 w/RE-71r's 305/30/19, eaton tru-trac
2007 2500HD Duramax, Built trans, custom tuned beast |
08-27-2016, 04:57 PM | #17 |
Drives: 2010 2SS/RS Join Date: Jun 2009
Lol it's the opposite of a few years back when everyone says you needed them. My builder recommended them and I did the upgrade. When I change my springs out I'll check the trunion as well
08-27-2016, 08:03 PM | #18 |
Drives: 2006 Z06 Join Date: Oct 2010
They are pumping metal shavings into your motor. Pull them asap. Stock or bronze is the way to go.
Nick
Corvette Z06 -1200ish rwhp |
08-27-2016, 08:24 PM | #19 |
Agreed
08-27-2016, 08:25 PM | #20 |
When mine fail I'm going bushings
08-27-2016, 08:38 PM | #21 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
Aftermarket vs stock. Funny how my stock ones were still good with a cam at 112K when I got the trunion upgrade done.
08-28-2016, 07:18 AM | #22 |
should I return my Comp Trunnions and get the Smith Brothers bronze ones or just keep stockers in.
08-28-2016, 07:32 AM | #23 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Not that I'm an expert but I was faced with the same choice (pre purchase) a few weeks ago and went Smith Bros...
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
08-28-2016, 07:36 AM | #24 |
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS Join Date: Jun 2015
I'm a believer in the stock rockers as well. I see more failures after people have screwed with them with the trunion stuff than ones that have just been left untouched.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold 2001 Camaro SS SOM M6- sold 1999 Firebird Formula A4- sold |
08-28-2016, 12:47 PM | #25 | |
Drives: Camaro Justice Join Date: Jun 2007
The COMP trunion kit is a high quality upgrade for stock motors and modest built motors using modest cams. The COMP Trunion kit is a Street part. If you are using big springs with a big cam, you are into what we refer to as low end race parts and should be using a different solution, a rocker SHAFT based set of low end race quality rockers. And don't forget to helicoil! Last edited by JusticePete; 08-28-2016 at 01:36 PM. |
08-28-2016, 01:28 PM | #26 | |
LS3 Stage II 3 Bolt Cam 225/238 .612"/.585" 113+3, they are grinding it with less aggressive lobes for a road racing application and I got the BTR double springs for .660 I believe.
08-28-2016, 01:30 PM | #27 |
08-28-2016, 01:42 PM | #28 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
I installed the comps, thought better then replaced with the smith brothers. So I have a set of comps that where never used, just pressed in and removed once to add to my collection of never to be used parts.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
