Roto-Fab
Old 08-16-2010, 11:29 AM   #1
Q8Y
Q8Y's Avatar
Drives: '12 F150
Looking for FI with the least heat problems
I from Kuwait and is mostly hot and humid as most of you know (122+ in the summer) and I'm looking for supercharger/turbocharger with the lowest IATs and heat soak.ofcourse I'm not going to drive it aggressively while it's this hot outside but it should provide constant good power at night (temps between 88-104) .I really like the idea of turbocharging but from what i hearf turbos are famous for heat soak.my car is an LS3 and the aim is to get to 600wrhp for now and it's not my daily drive only drive it weekends and I'm not a track user nor a racer just want some fun.I need something that will last with room to grow in the future planning to slowly push the stock LS3 until time to go forged.
The ones I'm considering are TTi-IPS tt-kenne bell because it's liquid cold (I don't know if maggies are)-vortech-eastcostsupercharging novi 1500
please help I'm kinda a newbie in this and if your in my place which one u choose
Thank you
recieved 7-10-09 2010 camaro black 2ss/RS/6m
Q8Y is offline   Reply With Quote
Old 08-16-2010, 11:53 AM   #2
SC2150
Drives: 2012 Camaro RS, RX supercharged
http://www.camaro5.com/forums/showthread.php?t=99515
FYI. Heat issues can be much less of an issue than they used to be.
SC2150 is offline   Reply With Quote
Old 08-17-2010, 10:34 AM   #3
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Personally if you are looking for the lowest intake charge I would suggest the STS turbo system. You get the benefits of a twin turbo car, but the turbos are not heating up the engine compartment... they are rear mounted.
If you need more info I am happy to help just PM me. That would be my personal choice for a hot climate.
ZZcamaro is offline   Reply With Quote
Old 08-17-2010, 10:43 AM   #4
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
i second the STS turbo route
trudawg660 is offline   Reply With Quote
Old 08-17-2010, 11:59 AM   #5
thekid96
Drives: Z06, 69 Camaro
Low mount turbos with a huge FMIC would be my first choice for lowest IAT and radiant heat. Centri would be second choice. The top mounts are always going to be limited by heat soak given their configuration and cooling system.
thekid96 is offline   Reply With Quote
Old 08-17-2010, 02:56 PM   #6
Q8Y
Q8Y's Avatar
Drives: '12 F150
Thanks all for your replies rear mounted from what I read in the forum suffer from lag
You mean like granettli and ips I think ips kit comes with larger intercooler I'm going to pm them both to check
Thanks again
Old 08-17-2010, 03:07 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
How did you come to this conclusion? While they may increase underhood temps a little, they shouldn't be prone to heatsoak any more than any other turbo configuration. Heatsoak is a IC problem, not a under hood temp problem. Everyone seems to forget that Supra's run their HUGE single turbo up top and make 1000+whp. It comes down to preference.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 08-17-2010, 03:31 PM   #8
thekid96
I was referring to heat soak as a result of top mount blowers being bolted directly to a 200+ degree motor. The case gets HOT and the intercooler is trapped below, doesn't help help IAT's. Fact is a big aluminum blower case is a heat sink and will draw heat from the motor, one of the reasons for liquid cooled cases.
Old 08-17-2010, 03:53 PM   #9
SC2150
The hotter the outside air temp, the better the super chiller works.....let me know if you need more details on the units and how they work. The link should cover most everything.
I have a couple of bad twin-turbo builds in Kuwait & surrounding countries also.
Old 08-17-2010, 04:12 PM   #10
IPSjeff
Drives: 2009 ZR1
Thanks again
Yep, you want the biggest / most efficient intercooler you can get to keep intake-temps down. Running 8psi or less certainly helps with that as well. Worst-case scenario would be to add a meth kit to any of the above mentioned set-ups just as added insurance
Jeff
IPSjeff is offline   Reply With Quote
Old 08-18-2010, 09:43 AM   #11
HaveBlue
HaveBlue's Avatar
Drives: CTS/CAMARO
The Edelbrock E-Force kit has a closed loop circulation system for the intercooler. Several shops have told me they see the lowest intake temps of any supercharger with this system.
My recomendation would be to talk with a shop that has done both and compare numbers.
"everyone wants to go to heaven. but nobody wants to die" "you gotta pay to play"
SEMA PICTURES-PARTS & CARS
http://www.pbase.com/haveblue/sema_2009
HaveBlue is offline   Reply With Quote
Old 08-18-2010, 09:51 AM   #12
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Hopefully we'll get some more insight
'20 ZL1 Black "Fury"
Old 08-18-2010, 04:28 PM   #13
Q8Y
Q8Y's Avatar
Drives: '12 F150
The thing is about the E-force is restricted for future upgrades.
Jeff have done any testing in hot weather??
Please PM me your price shipped to kuwait
Old 08-18-2010, 05:30 PM   #14
old motorhead
Drives: Maggie blown LS3 vette
"Lowest intake temps of any supercharger?" Would that include the centrifugals also? If so, I find that really hard to believe. I'm also guessing that all of the top mount 'chargers have a "closed loop" coolant circulation system. What other way could it be done?
old motorhead is offline   Reply With Quote
1st and 2nd gear problems. 1SS 6M jnm2003 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 7 10-29-2019 12:22 PM
Automatic Transmission Problems Kyzer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 30 07-13-2016 06:26 PM
Long Problem(s) GM techs or someone needed here... xpanda305x Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 37 07-04-2010 02:00 PM
M6 CLUTCH/TRANS PROBLEMS summitss/rsls3 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 05-22-2010 11:48 AM
