02-25-2013, 09:40 PM | #1 |
Drives: Cars Join Date: Feb 2013
Debating between LS and LT
I am debating choices, so I was wondering if you guys can help.
So I plan on buying a V6, but I don't know whether or not to buy an LS or LT. I am 80% positive I will turbocharge the car, or twin turbos. I was wondering if it is better to just buy a 1LS and add leather seats, and just build it how I want. Or buy a used 2LT/RS and go from there. The 1LS sounds more fun because I do what I want to it and it will be new. So tell me what you would do? |
02-25-2013, 09:46 PM | #2 | |
Drives: 2012 45th Vert 2LT/RS Join Date: Apr 2012
Nice name by the way!
02-25-2013, 09:55 PM | #3 |
Drives: 2013 silver ice metallic ZL1 Join Date: Jan 2013
Buy a used SS!!
02-25-2013, 10:33 PM | #4 |
Drives: 2015 2SS/RS Join Date: Apr 2012
I bought a 1LT car. Cloth interior like the 1LS (2012 cars, BTW) but it had the firmer suspension package, power seats on both sides, true Sport Mode and paddle shifting on the transmission (different programming in the 2LS cars), fog lights, more performance oriented rear end gear ratio, nicer stock wheels (aluminum 18s vs steel 18s) and a factory spoiler. The little bit of money was well worth the changes.
Granted the differences in 2013 may be different. I know the LS car comes with the old radio now while everything above that has the My Link, for example.
2015 Camaro 2SS/RS SIM
2016 Jeep Wrangler 2DR Willys Wheeler 1993 C1500 Single Cab Stepside 5.3L LS Swap |
02-25-2013, 11:01 PM | #5 | |
Drives: 2014 Camaro 1SS/RS M6 Join Date: Dec 2011
02-25-2013, 11:02 PM | #6 |
02-25-2013, 11:54 PM | #7 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
You're quoting gas prices when you say you're going to turbo it?
Sorry, got you confused with the OP.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
02-25-2013, 11:57 PM | #8 |
Drives: 2012 1SS LS3 M6 black on black :) Join Date: May 2012
You can always get the LS and add leather seats later on if you want. There are some here that did some diy and have threads on changing the cloth out for leather.
02-26-2013, 12:07 AM | #9 |
Don't tread on me
Drives: 23 Sierra X31, Past 2017 Fifty 2SS Join Date: Nov 2012
If I truly wanted to buy a v6 and replace everything in it I'd probably go 1LS. There's a couple of members on here who started out with LS cars and they're as sharp as ZL1's. don't know their names but one of them has a synergy green and the other has a white one.
But whatever you do make your first project be to change out the steelies. |
02-26-2013, 08:19 AM | #10 | |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Another consideration, based on what the OP is talking about doing to the car, is the electronic speed limiter, which is set at the factory based on the speed rating of the tires the car comes originally equipped with. The LS is set at 118 mph, I believe, until you get up to the 2LT (which comes with Z rated tires, I think-someone will correct me if I'm wrong). I think the 2LT is limited to 145 mph, and the RS models get W rated tires, so the 6 cylinder RS's get a limiter bump to 155 mph. Of course, all that can be changed with a tune, which if you're talking about turbocharging anyway, you're probably gonna do. EDIT: I stand corrected; according to http://www.google.com/url?sa=t&sourc...pZIojGrLuCpclAthis brochure, the LS models and 1LTs with 18" wheels are limited to 113 mph, the other v6's are limited at 155 mph. Wow, giant Tapatalk link insert fail. :(
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting Last edited by 911medic; 02-26-2013 at 11:25 AM. |
02-26-2013, 08:41 AM | #11 |
The guy talking about turbocharging (the OP) and the guy talking about gas prices are not the same.
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
02-26-2013, 08:44 AM | #12 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Our turbo builds still get 28 mpg on the interstate......and power to beat most un modded SS's in the 1/4 mile.
02-26-2013, 09:08 AM | #13 | |
You could be right. I just know the window sticker on the LT cars said 'Sport Suspension' while the LS cars said nothing at all. Probably just differently valved shocks if anything. I will compare RPO codes one day.
02-26-2013, 09:10 AM | #14 | |
Drives: '11 2SS/RS L99, '12 2LS LFX Join Date: Jul 2010
