01-02-2024, 01:45 PM | #1 |
Drives: 2013 SS LS3, NPP, Blk Join Date: Sep 2012
Future NPP Replacement Question
Happy new year everyone!
I am looking for somethings to learn about and thought it may be fun to ask this question here and start some 2024 activity up Inevitably one day on my car I am going to need to replace the muffler which is the NPP. What does one do in this situation considering: 1) The dual-mode valves which looks to be welded to the muffler (to my unexperienced eye) 2) I want to keep the look and sound considering the wider quad-tip cutouts in the diffuser 3) as I read, but have not confirmed, that the factory NPP kit is no longer being sold. Is this a case of bring it to a muffler shop and have them repair cut and weld as required?
1LE Suspension Kit, 1LE Strut Brace, dynosteve tune, K&N Typhoon CAI, Goodridge SS Brake Lines, JLT 2.0 Catch Can, NPP Exhaust Mod
01-03-2024, 05:29 AM | #2 |
Here is a set about 50 miles away from you just over the border @ the Rainbow Bridge in Tonawanda NY. If this looks like an option, put in a low offer & see what they counter offer. I have bought a lot of parts from them.
https://www.ebay.com/itm/124168202746
01-04-2024, 02:39 PM | #3 |
Thank you very much for sharing this! I will bookmark their store and check them out when the time comes due. Great idea to look for shops like that thanks a ton!
01-07-2024, 06:54 AM | #4 |
Parts for these cars are getting pretty scarce. If you a worried about it, you probably want to think about building up a stash. On the bright side, if a part is common enough, the after market will come up with a replacement unit. There are a bunch of cars with NPP mufflers, not just the Camaro, so somebody will likely make one. Another option is a complete muffler delete
01-09-2024, 07:38 PM | #5 |
Muffler delete does seem to answer all the problems doesn't it lol
