12-02-2023, 11:44 PM | #1 |
Drives: Chevy camaro SS Join Date: May 2020
Can a 103 mm throttle body on existing factory intake maniflod?
I have an existing manufacture's intake manifold, I bought a 103 throttle because my current throttle body hestiate on accleration. the 103 will mount up to the existing manufacture intake manifold however it idles high and it surges. I ask the tuner for a tune but he indicates that it will not work on this size of engine. I was just wondering if anyone tried to upgrade orginal throttle body to 103mm an had success with it? I have a 2010 SS LS3 6.2L
Sincerely, BlackBird1 |
12-03-2023, 08:22 AM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
It won't fit on a stock intake. It might bolt up and plug in, but it won't work.
12-03-2023, 08:30 AM | #3 |
This will help you. Nothing to be gained with a 103 on a stock ls3.
https://gwatneyperformance.com/103mm...ow-much-power/
12-03-2023, 09:11 AM | #4 | |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
12-04-2023, 12:33 PM | #5 |
All of the above!! Agreed..
