Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 05-11-2013, 03:04 PM   #1
2012_1LT/RS
Drives: 2012 Camaro 1LT/RS
Diff. Fluid change?
This has probably been asked 1,000 times, but I can not seem to find the answer I am looking for anywhere. I have a 2012 V6 Automatic with 10,000 miles on it so I know I am do for a diff change. I know I don't need the additive in the diff fluid but if I put Royal Purple in mine will the additive that's in it already mess up my diff.
2012_1LT/RS is offline   Reply With Quote
Old 05-11-2013, 03:25 PM   #2
Oldag
Drives: 2013 2SS Convertible, LS3
I have never heard of changing differential fluid at 10k miles. Maybe for racing?
Oldag is offline   Reply With Quote
Old 05-11-2013, 03:27 PM   #3
2012_1LT/RS
No just been reading some of the older theads and just mainly for a piece of mind more than anything else
Old 05-11-2013, 03:33 PM   #4
Indy Bumble Bee
Indy Bumble Bee's Avatar
Drives: Beest
I did mine at 13k. Noticed an improvement and trust me it was dirty of shavings. Glad I did. I put in RP and it took 10 minutes or so. I highly recommend it
Btw just add the new oil and do some figure 8's in the parking lot
Indy Bumble Bee is offline   Reply With Quote
Old 05-11-2013, 03:38 PM   #5
jwoair23
jwoair23's Avatar
Drives: 2010 Camaro 2LT
I changed mine at 50K and put in Royal Purple. I am at 64K now and have had no issues!
jwoair23 is offline   Reply With Quote
Old 05-11-2013, 03:39 PM   #6
2012_1LT/RS
And you guys have automatics right? And thanks for the input.
Old 05-11-2013, 03:47 PM   #7
Indy Bumble Bee
Drives: Beest
Yes mine is an auto. It's just like changing your oil.
Old 05-11-2013, 07:17 PM   #8
jwoair23
jwoair23's Avatar
Auto here also!
Old 05-11-2013, 08:30 PM   #9
2012_1LT/RS
Cool thanks guys finished it right after the post went off without a hitch no issues
Old 05-11-2013, 08:34 PM   #10
Indy Bumble Bee
Drives: Beest
Awesome!
Old 05-11-2013, 08:46 PM   #11
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Is there a drain plug or do you have to remove the cover (thanks for saving me from looking under the car)
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 05-11-2013, 08:48 PM   #12
mickmosh
Drives: 2018 Camaro ZL1
Drain plug and fill is on the driver side. Not too bad did mine today
mickmosh is offline   Reply With Quote
Old 05-11-2013, 09:07 PM   #13
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Good Job. Tip of the day for others. Remove the fill plug first. No sense removing the drain plug first only to find you cannot get the fill plug out. Then you have problems.
I did mine at 2300 miles to dump the stock fluid and any shavings. Then again at 25K. Wanted to see what it looked like since I had been down the track a number of times.
I went with Royal Purple. I have an automatic. Just like changing oil. Nothing to it.
rtcat600man is offline   Reply With Quote
Old 05-11-2013, 11:00 PM   #14
SPCBA
Drives: pleather and Chiclets
change it, make sure you get a good oil and the slip additive...wait i am clueless on v6 does their rearend need the slip additive?
SPCBA is offline   Reply With Quote
