Old 01-29-2019, 09:25 PM   #1
rsrsrs
rsrsrs's Avatar
Drives: '11 2SS/RS M6
Can someone explain to me what happened here?
Pulling into work, heard a nice knock and crunch come from the front driver side wheel. Turned the wheel and I see this
I contacted BMR since that's where I bought the front end links from. They asked me what that metal piece was hanging by the end link. I wasnt able to get under the car since I was at work so I drove home.It was pouring rain so I wasn't able to put it up on a jack and remove the wheel. Took some pics and this is what it looked like from the front.
I'm just confused, if the sway bar did snap, which looks to be the case, how did the end link unscrew itself from the rod? And if the Sway Bar did snap, why is said screw still hanging on by the Sway Bar and not sitting in the End Link?
2011 Camaro SS LS3
End Links are BMR
Front Sway Bar is Pfadt
Adjustable Coilovers are BC Racing
Any thoughts, upgrade suggestions are appreciated thanks. List of mods done to car
2011 Camaro 2SS LS3 564rwhp Torque I'd have to look that up again
Whipple SuperCharger
Cold Air Inductions CAI
MGW Short Shifter
American Racing Long Tube Headers
Borla ATAK Catback exhaust w/X-Pipe
Gutted Cats
BC Racing Adjustable Coilovers
Pfadt Race Engineering Solid Subframe Bushings
Pfadt Race Engineering Differential Bushings
Pfadt Race Engineering Rear Arm Package
Pfadt Race Engineering Adjustable Sway Bar - Sport - Front and Rear
Pfadt Race Engineering Rear Sway Bar End Links
BMR Front End Links
rsrsrs is offline   Reply With Quote
Old 01-30-2019, 06:31 AM   #2
rsrsrs
rsrsrs's Avatar
Was able to take the wheel off off this morning. Sway Bar is actually fine! Weirdly enough I was actually able to Slide the end link bolt into the rod...
Old 01-30-2019, 06:52 AM   #3
ybnormal70
Drives: 2010 Camaro SS
Looks to me like it stripped out of the end of the link. Maybe not enough thread engagement when installed? Not sure.
Kevin
ybnormal70 is offline   Reply With Quote
Old 01-30-2019, 08:33 AM   #4
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
agreed, usually the endlink breaks first. I know...
Old 01-30-2019, 09:42 AM   #5
rsrsrs
rsrsrs's Avatar
Kevin
BMR basically said this as well, wonder if not enough threads engaged before it pulled out."
Guess I'll be looking into this in the cold tonight, Yay.
Old 01-30-2019, 11:30 AM   #6
rsrsrs
rsrsrs's Avatar
Oh I know as well. Had the rear loosen up and then break on me and had the front passenger bend as well.
Old 02-04-2019, 06:18 AM   #7
hrpiii
AKA "Beefcake"
hrpiii's Avatar
I've only broken ones on the back, twice. You really did something special to bend the front one. Most likely a pothole or something like that.
bmr, end links, pfadt, sway bar
