04-16-2018, 02:38 PM | #71 | |
It was just a thought. |
04-16-2018, 04:39 PM | #72 |
Drives: 2010 2LT/RS Join Date: Mar 2015
I believe you and wouldn't want to shave the tires. If they are out of round and defective, I believe it is truly TireRack's responsibility to replace them. As I have asked before and no one seemed to answer as of yet, how do I prove they are defective?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
04-16-2018, 04:41 PM | #73 |
All of the mods on my car are mostly OEM upgrades. Not aftermarket. The only aftermarket parts would be the TPIS strut tower adapters, Flowmasters and K&N Air CAI to name a few. None of which affect the steering wheel vibration issues I have been experiencing.
2010 2LT/RS
04-16-2018, 05:31 PM | #74 |
Another far-fetched idea would be the possibility of a worn/bad wheel bearing.
04-16-2018, 06:03 PM | #75 | |
Dealer found little to no play in the wheel bearings. Suspension checked out okay as well. Sent from my iPhone using Tapatalk
2010 2LT/RS
04-16-2018, 07:24 PM | #76 |
Drives: 2010 RS/SS Join Date: Jul 2017
I would jack the front end up to where the tires are barely off the ground and spin them. I've had out of round tires before and figured it out that way, as was mentioned in an earlier post. Easy check.
04-16-2018, 08:48 PM | #77 |
Drives: 2012 Camaro 2SS Join Date: Aug 2017
Someone told me it cold be the calipers if they are slightly warped. My car does it too and I had the wheels balanced and I still have it a bit. But I'm going to wait till I need new brakes.
Texas Speed Long tubes, highflow cats, Borla Cat back S-Type, Spectre Cold Air Intake, HP tuner tune
04-16-2018, 09:16 PM | #78 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
Remember no issues until the new tires we installed.
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
04-16-2018, 09:16 PM | #79 |
I assume you mean the rotors could be slightly warped? If so that is good information to consider.
2010 2LT/RS
04-16-2018, 09:17 PM | #80 |
2010 2LT/RS
04-16-2018, 09:24 PM | #81 |
Any chance you can find another car that you can temporarily swap all wheels/tires with to see what happens?
Put their wheels/tires on your car and see what happens, as well as you mount your set on their car and see how their car rides? Check to see if the vibration issue stays with the car or stays with the wheels/tires. |
04-16-2018, 09:26 PM | #82 | |
I wish i could. I do not know anyone else down here in South Florida with a 5th Gen let alone a 6th. Sent from my iPhone using Tapatalk
2010 2LT/RS
04-17-2018, 05:49 AM | #83 |
OOpse
OOpse ... yup. I was tired : )
04-17-2018, 06:47 AM | #84 |
"SHARK" Born Apr.26,2011
Drives: 2011 CGM 2LT/RS Convertible Join Date: Oct 2011
I would say probably the tires, since you did not have problems until you changed tires.
This is what I would suggest......find a GM dealer, preferably one that sells/services alot of corvettes, so they would be used to higher performance car problems......see if they have a used Camaro for sale.....pay for them to pull the wheel sets (rims and tires) off the used car and put them on yours for a test drive.....that is assuming the used wheel sets are in good condition....if no vibration on yours, then you would have found the problem. I still would start with the tires as this is the variable that you have changed.... |
