04-15-2018, 09:12 AM | #57 |
Drives: too many to say! Join Date: Nov 2010
What kind of numbers did the road force give? Have they taken the tires off and remounted at all? Sometimes tires won't fully seat to the rim. Have they used a Picoscope to find what frequencies are showing up?
04-15-2018, 11:26 AM | #58 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
Not sure on the numbers. But they said it was spot on and to specs. Pretty doubtful they took the tires off the front and remounted. They did remove the rears to remove nails and patch them up from the insides. Sent from my iPhone using Tapatalk
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
04-15-2018, 11:31 AM | #59 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Oem wheels are hubcentric and the lugs would not affect anything. That means the wheels fit over the hubs to do the centering and lugs only apply the clamping force to hold the wheel to the hub
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
04-15-2018, 11:59 AM | #60 | |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
The "out of round" tires didn't cause issues at speeds below 35mph and above 48mph.
04-15-2018, 12:06 PM | #61 | |
However, one thing that comes to mind, although it's a bit far fetched, is the possibility that the wheel(s) wasn't sitting completely flat against the rotor. If the face of the rotor or rear face of the wheel weren't clean and flat (perhaps a small piece of something was sticking to a surface), when the wheel was mounted , it might not sit completely flat and you might end up with a slight wobble. Another possibility. IF you had aftermarket wheels on the car that require the use of a hub ring. If the hub ring isn't seated completely and properly, it could cause the wheel to not seat flat on the rotor. If you had aftermarket wheels that require hub rings on the car at one time but then changed the wheels back to the stock wheels that don't require the hub rings. You might have forgotten to remove the hub rings (DAMHIKT), again preventing the wheels from sitting flat on the rotor. |
04-15-2018, 12:08 PM | #62 | |
The wheels have been on and off the car several times when going in between wheel balancing at least maybe 6 times within the past year. Sent from my iPhone using Tapatalk
2010 2LT/RS
04-15-2018, 06:46 PM | #63 | |
Fast Cars and Old Guitars
If you can stomach watching your $1400 tires being shaved!
04-15-2018, 07:30 PM | #64 |
That was cool to watch Didn’t know that could be done. Who does this procedure if needed? Sent from my iPhone using Tapatalk
2010 2LT/RS
04-15-2018, 08:26 PM | #65 |
Shaving tread won't help with a out of round problem, it's in the casing/ belts
04-15-2018, 08:29 PM | #66 |
Sorry to say but you are going to need different tires to fix your problem. Take it or leave it "My advice" I do have close to 15 years in the tire business and seen new tires with many many manufacture deficits
04-15-2018, 08:32 PM | #67 |
Cooper is a good cost effective performance tire brand , they make Micky Thompson tires for them if that says anything for there quality
04-16-2018, 12:41 PM | #68 | |
Drives: 2014 Camaro SS Join Date: Mar 2016
04-16-2018, 01:51 PM | #69 | |
That's why you do the work your self , you know it's done right and can find the problems your self because you know were to look and what has changed. Paying other to do anything but tune the ecu is not good idea , ask any gear head out there all will say the same
04-16-2018, 01:57 PM | #70 |
Even top tuner/mod shop workers would not let other guy touch there car. It's like having a wife and letting other guys please her
