08-30-2014, 10:13 PM | #15 |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
Second this.
Consensus is, by definition, a lack of leadership.
08-30-2014, 11:43 PM | #16 | |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
I suspect a lot of people delete the cats and the resonators or go with high flow cats straight back to the tailpipe was no resonator and no muffler. Maybe this creates the rasp? Dunno. There are some YouTube videos demonstrating nice sound by keeping the resonators and deleting the muffler. As for me .. I plan to move to high flow cats, drop the resonators and keep the NPP. Fingers crossed that I'll like this sound.
08-31-2014, 10:01 AM | #17 |
Drives: 2014 BRM, 2SS, RS, 1LE Join Date: Jun 2013
I went to NicKey yesterday....which is about 45 minutes from me and I must say, Stefano and his shop are top notch. He talked me through everything he'd do, he showed me all of the parts and gave me a sound demo of a few cars. We shot the shit for like and hour!
I'm taking my car there for sure. I just have to play the weather game. I've got to get it there on a day it won't rain. The weather in Chicago is streaky. As for the tune....as long as they'll cover parts outside of the motor, I'm fine. They can't deny a power window because of a tune. |
08-31-2014, 10:28 AM | #18 |
Drives: ‘13 1LE Join Date: Jul 2013
So all you guys here, who are essentially building bolt-on modded cars, with no tune for warranties sake, are saying that there is no KR happening at higher rpm's and WOT????
I'm thinking that in theory there should be, you should be running lean right? But wait, since you would have no tune, then the oem protocol would be to use the lower octane fuel map, hence the infamous fuse pull, so that the high octane parameters are set in place again. Thinking out loud here until a guru chimes in to set me straight. |
08-31-2014, 10:40 AM | #19 |
Always Workin
Drives: 2021 Mazda MX-5 Join Date: Aug 2013
Stainless Works Headers
No Cats 3" Stainless Works chambered exhaust Dyno Tuned CAI, Ported TB, etc... I love the sound, its loud but not to loud and there is no drone. I have a video its not the greatest quality and doesn't do that car justice lol http://youtu.be/O1aYcEyCflY
2023 Vivid Orange 1SS 1LE 6MT
Arrived 8/31 Purchased 9/3 2018 1SS 1LE, HyperBlue Metallic (Sold) 2014 1SS 1LE, Black, Twin Turbo (Sold) |
08-31-2014, 01:10 PM | #20 | |
Drives: '16 C7 Z51 Join Date: May 2012
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
08-31-2014, 03:23 PM | #21 | |
I mentioned this because a buddy's logs showed a lil KR happening in the higher rpm guages with scoop and cold air intake. I think Ted from JRE once wrote, headers will not lean out your AFR ratio, but depending on brand of cold air intake, it can lean out. |
08-31-2014, 03:32 PM | #22 | |
Drives: E92 BMW M3 Join Date: Oct 2012
J-Rod Built and Matt@FSP Tuned |
08-31-2014, 04:06 PM | #23 | |
Originally I planned to remain stock and not muck with the program module but, really, if I'm going to make multiple changes (CAI, resonator delete, shorty headers, mid pipes with high flow cats, o2 sensor extender), albeit all bolt-on in nature, I figured it's wise to think about a proper tune. Then again I'm trying to logically speculate here so I don't know what I don't know. I'm sure "Ted" will want to sell me a tuner and a program but I'm also hoping/expecting that his advice will be clinical with an honest assessment of what's needed vs what's optional. Does anyone have advice? OP, what did you learn from your one hour "shoot the shi^" session with the Chicago tuning guy?
08-31-2014, 04:08 PM | #24 | |
08-31-2014, 04:14 PM | #25 |
KR means Knock Retard.
You can datalog and check to see if you have any. AFR means Air Fuel Ratio. You can datalog and look at your fuel trims at partial throttle since it's still in closed loop. For WOT (wide open throttle) AFR readings, you would need a wideband air fuel ratio meter, preferably hooked up pre cat. |
08-31-2014, 05:00 PM | #26 |
I decided to go with inTune device ($389 shipped) with a custom tune from Florida Speed ($100 option when you buy the device from them) tailored to my car's mods (and logs that I will provide). A safe tune that brings the numbers within the ballpark of ideal is more than enough for me, since it usually also translates to a very safe tune that works in every condition and environment.
I just got the headers coated, and once I am done installing headers and the tune, I will take it to dyno for a sanity check. I will keep my build thread updated with my progress.
