TireRack
Old 10-14-2011, 09:28 PM   #1
NipTuckTaxi
NipTuckTaxi's Avatar
Drives: 2010 Camaro 1SS
ANOTHER reduced engine power incident.
well, i resolved the issue of my throttle postion sensor from last week.
NOW... i turned off stabil trak. Floored the car from a dead stop. got a little wheel hop. "Service stabil trak" message appeared ...then back to reduced engine power. so i limped it back home on 4 cylinders and cleared the code. it comes back anytime i hammer on the accelerator. the car rolls fine. did not hear or see anything broken other than the codes and messages and reducing my power. any takers on this one?
thanks.
2010 SS: ERL 416; AGP TT; Century Super 6L80; Strange S60. Supporting mods in between. 650rwhp\ 700 rwtq.
NipTuckTaxi is offline   Reply With Quote
Old 10-14-2011, 09:30 PM   #2
NipTuckTaxi
the new code is P0651.
Old 10-14-2011, 10:28 PM   #3
oldfriend
Drives: Fiat 500 E
Had that issue a couple times ,took the car to the dealer and bam , no more crap like that ,,,,,,,black wood
oldfriend is offline   Reply With Quote
Old 10-14-2011, 11:00 PM   #4
Parag
Drives: 2010 camaro 2SS LS3
sounds like the throttle body is opening too far, the computer has to relearn where the max value is. not sure how to fix that. maybe just time
Parag is offline   Reply With Quote
Old 10-15-2011, 06:03 PM   #5
NipTuckTaxi
PCM voltage out of tolerance condition oon the 5-volt reference circuit.
all my connections are tight. no burns, kinks or marks.
any idea what may be happening?
Old 10-15-2011, 07:12 PM   #6
Parag
P0651 Sensor Reference Voltage B Circuit/Open
looks like time for a ported throttle body
Old 10-15-2011, 07:54 PM   #7
NipTuckTaxi
I just installed one a few hours prior to all this. First. Time wot and bam. I got stabiltrak service message and reduced engine power. I can get 8cylinders back as long as I don't get aggressive. If I do then its back to reduced power.
Old 10-15-2011, 08:22 PM   #8
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Take apart your wiring harness on the throttle body and take a close look to make sure one of your male pins is not bent. Also check any grounds that may have loosened.
Tampa Tuning is offline   Reply With Quote
Old 10-15-2011, 08:38 PM   #9
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
thanks.
Is this an EFI Live tune,Just wondering
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
LSX-80MM is offline   Reply With Quote
Old 10-16-2011, 04:43 AM   #10
NipTuckTaxi
i have inspected all of the grounds and connections and nothing is out of the ordinary.
im not sure what an EFI live tune is .
Old 10-16-2011, 10:26 AM   #11
Bay Area SS
Bay Area SS's Avatar
Drives: 2010 rs/2ss
same exact thing happened to me. My headers burned the wiring harness for the 02 extensions and it was fryin fuses. thank god I was literally pullin into my dyno shop when this happened. He had to rewire some stuff. . .
1 7/8 long tubes full XS Power exhaust no cats, Rotofab CAI, PowderPro Ported TB, Hurst short throw, TSP 231 236 cam, tuned by Synergy Motorsports 454RWHP, 440 RWTQ. More to come!
Bay Area SS is offline   Reply With Quote
Old 10-16-2011, 10:29 AM   #12
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
It's a Tuning Software like hpTuners...You need to find a good tuner,and they are PRICELESS.Good luck with your problem.....
Old 10-20-2011, 04:05 AM   #13
NipTuckTaxi
I still cant find anything out of the ordinary with the naked eye.
Im am kind of reluctant to send it to the dealership.
Can anyone recommend a good electronics tech/mechanic for this type of issue in the southern US?
Old 10-20-2011, 07:33 AM   #14
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
bring that thing to Atlanta my shop can fix it right. guarantee it
JLE58 is offline   Reply With Quote
New Texas Speed & Performance Engine Machining Center! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 18 01-16-2013 03:46 PM
engine power is reduced??? sswish 5th Gen Camaro SS LS LT General Discussions 9 10-22-2010 04:52 AM
Mustangs................ vontivonti 5th Gen Camaro SS LS LT General Discussions 4052 12-21-2009 10:42 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 07:37 PM
