02-23-2016, 03:52 PM | #211 |
Drives: 1996 Toyota Corolla Join Date: Nov 2014
I'm wondering if it makes a difference the level of fuel you have in your tank, after running a few tanks of high-octane only to be on the safe side.
03-01-2016, 03:26 PM | #212 |
Drives: 2000 Camaro SS Join Date: Feb 2010
I would run 2-3 tanks of premium down as low as you can to make sure you get all the low grade stuff out before you do it.
03-06-2016, 06:36 AM | #213 |
Drives: 45th Anniversary 2SS V8 426hp 6.2l Join Date: Feb 2016
Im not going to be the umpteenth person to ask how or why to do this or if it works. My question is... is there a faster way to clear the memory of the octane tables without letting it sit overnight? Maybe something with the battery or elsewhere? (please assume I have no tuner equipment and that Im just a plain driver)
03-22-2016, 09:21 AM | #214 | |
03-24-2016, 03:47 PM | #215 |
Drives: 2007 Chevy TrailBlazer SS Join Date: Mar 2016
Thanks for the info! this is great!
04-19-2016, 07:45 AM | #216 |
04-19-2016, 03:35 PM | #217 |
Drives: Blue Ray 2SS Join Date: Jul 2013
I've looked through the entire thread and didn't find the answer and I apologize in advance if I missed it.
I disconnect the battery each winter when I store my 2013 2SS and was wondering if that is enough to reset it or do I still have to do the fuse pull? Paul |
05-04-2016, 02:52 PM | #218 |
That will take care of it. As long as you are keeping premium in it you don't have to worry.
05-11-2016, 03:25 PM | #219 |
Door ding magnet
I recently bought a GoPoint BT1 bluetooth ODB2 adapter. Is it possible to view which timing map is currently active and if so, which iPhone app can do it?
Years ago I had the low power issue and even had the car on a dyno to prove it. I didn't go back after I learned of the fuse pull to verify it worked, but I did a few 0-60 runs and they were quicker. It would be nice to check using the ODB2 app to know for sure which fuel map the car is using.
"When you're racing, it's life. Anything that happens before or after is just waiting." |
05-11-2016, 05:18 PM | #220 | |
07-18-2016, 09:18 AM | #221 |
Drives: 2013 SS Camaro Join Date: May 2016
This worked 4 me!...faster crank at startup ...also its more reseponsive 😊 Thanks for sharing this tip.....bump
Sent from my SM-N920P using Tapatalk |
07-18-2016, 09:47 AM | #222 |
Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
I guess it's my turn next tonight...
07-19-2016, 07:47 PM | #223 |
Drives: 2021 Camaro SS Convertible Join Date: Apr 2016
So, for giggles, I did this today while at work. I pulled the fuses at 6:30Am and reinstalled them at 2:30PM. I've been running 91+ octane for about a month along with my Range to deactivate AFM. I filled up this morning before work and had a 213 mile fuel range by the time I arrived at work.
When I restarted the car, it started stronger and quicker than what I was use to. The first thing I noticed was the fuel range, it had increased by 20 miles to 233!!! it's not much, but I'll take it. Also the throttle was more responsive and the shifting seemed smoother to me. I'm a believer! Thanks for the tip! |
07-19-2016, 08:01 PM | #224 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
I think most of this is placebo I highly doubt you would feel much of a difference from this. And doesn't the fuel range always say it increases after it's been sitting?
Pity a man in familiar places, who yet feels like a stranger.
apex, fuse pull, high octane fuel |
