Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 05-12-2013, 06:15 AM   #15
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Originally Posted by SPCBA View Post
change it, make sure you get a good oil and the slip additive...wait i am clueless on v6 does their rearend need the slip additive?
Yes, if it is a manual.
rtcat600man is offline   Reply With Quote
Old 05-12-2013, 04:50 PM   #16
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
I changed my fluid at approx. 8,000 miles. I used 1 quart of Amsoil and 4.5 oz of GM posi additive. The owner's manual actually recommends changing the rear end fluid @ 3,000 miles if the car is used for competiton/racing. I don't race my car so changing the fluid at 8,000 was more like a peace of mind for me. Plus, it gets rid of excess metal shavings from vehicle break-in. I also wanted to add good quality stuff like Amsoil. The process is as easy as changing engine oil so I figured, why not?
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 05-13-2013, 12:45 AM   #17
coreyaustin17
NEC5 C-HOLE CHAMP
coreyaustin17's Avatar
Drives: 2013 camaro 2SS/RS 1LE 1 of 221
even for a manual?? never done any diff fluid work
coreyaustin17 is offline   Reply With Quote
Old 05-13-2013, 08:44 AM   #18
Indy Bumble Bee
Indy Bumble Bee's Avatar
Drives: Beest
Too clarify changing rear diff. on a v6...
Automatic no additive needed
Manual-additive needed
Like rtcat600man said...after the car is jacked up, take out the top bolt first and clean off the plug...make sure you keep the o-ring if it falls off when you take it out.
Next, put a pan under the bottom plug and take out that plug. (BEWARE use gloves!!!! This fluid is nasty smelling and it is difficult to get rid of). Again, clean that plug.
Some people move their jack up and down to get every last drop. I didn't find this necessary so I just put the bottom plug in. It is a little tricky getting the fluid bottle to fit correctly to fill the the top plug. You may have to squeeze the bottle and move it around to get it to go in. Then put the top plug back in.
After you have the plugs in, take if into a parking lot and do some figure 8's to get the fluid moving around the gears.
http://www.camaro5.com/forums/showthread.php?t=161654
This is the thread I went by when I changed mine.
Indy Bumble Bee is offline   Reply With Quote
Old 05-13-2013, 10:39 AM   #19
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Changed ours for the first time at 700miles and was amazed how bad the fluid was and magnets were both full of metal, again changed it at 5000miles and 10000miles and fluid looked great used mobil 1 full syn at each change
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 05-14-2013, 08:31 AM   #20
tonyko1
Drives: 2012 Camaro 2SS/RS Convertible, IBM
The differential fluid from the factory is synthetic, and good for many miles, under normal driving, not drag racing or beating on the rear-end with burnouts.
Of course the oil looks like heck, the gears are meshing together and forming a good fit together, kind of like when the Beatles added Ringo. There is no need to change it early (<50-70k miles) unless you feel better about it. You want the gears to wear together, that is the way gears are.
However, people on this forum love to change fluids early, and it is their money and time, so rock on.
tonyko1 is offline   Reply With Quote
Old 05-14-2013, 08:49 PM   #21
ICTsccaCamaro
ITCRNRS
2qts of 75w90 is very cheap, definitely wouldn't want all those metal particals floating around in my rear axle for 50-70k
Old 05-15-2013, 01:47 AM   #22
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
I'd bet that a V-6 auto's open diff's fluid would look far better at 1000 miles on the odometer than a V-6 manual or an SS with a limited slip. Much of what we're seeing on the magnets is clutch material. Mine were pretty cruddy at 1500 miles. Should decrease quite a bit after the first change.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-15-2013, 08:37 AM   #23
ICTsccaCamaro
ITCRNRS
Seeing how ours has no clutches in the rear end and our fluid was very black and burnt at 700miles both magnets packed full, maybe it has to do with what our car has to put up with every other sunday?
Old 05-15-2013, 10:05 AM   #24
JohnnyBfromPeoria
Quite likely!
John B.
Old 06-26-2013, 03:55 PM   #25
London-SS
Drives: 2010 Chevy Camaro 2SS/RS
Does the V8 auto require an additive?Sorry,I'm clue less :(
London-SS is offline   Reply With Quote
Old 06-26-2013, 07:37 PM   #26
ICTsccaCamaro
ITCRNRS
Yes only camaro that does not need additive is a V6 auto
Old 07-01-2013, 04:12 AM   #27
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
you should be changing it by 1500 miles for the 1st time. Everything needs to break in. The fluid will be bad by then. then you can go with the recommended intervals. just change it every 10,000.
Old 07-01-2013, 10:26 AM   #28
butters
butters's Avatar
Drives: 2010 2SS/RS L99
thanks for the write up
butters is offline   Reply With Quote
