Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 05-15-2012, 09:35 AM   #1
drakedgar
drakedgar's Avatar
Drives: 16' 2SS Camaro, 10' 1LT RS Camaro
MACE 25 mm Insulator vs RX Black Ice insulator
hi guys,
I have been reading a lot about insulators latetly; especially about Mace's 25 mm and RX Black Ice insulator.
Right now they both seems to work well and haven't heard any complains...
Still haven't read of a big difference between them either....
So my question is... What's the main difference between then?
-Ed
Edit: I meant to post this on the LLT Section
drakedgar is offline   Reply With Quote
Old 05-15-2012, 11:31 AM   #2
bmorecam
Drives: jealous vendors mad!! HAHA!!
RX if you want couple more hp pass 6k rpm. MACE if you want low to mid boost up to over 10 extra ft lb of tq around 4k rpm.
I would do MACE hands down, VMAX version is not bad either but one thing I don't like is the fact that it does not match to stock cylinder head and intake manifold holes which will create turbulence in high rpm unless you grind off the edge of the cylinder head.
Both good, but MACE all the way for me!!
bmorecam is offline   Reply With Quote
Old 05-15-2012, 11:35 AM   #3
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
I agree, these motors wind up fast at 4k+, the mace added a noticeable gain just below that.....
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 05-15-2012, 03:54 PM   #4
SC2150
Drives: 2012 Camaro RS, RX supercharged
The VMax matches the intake manifold gasket opening exactley and is a one piece design to give as much isolation of radiant heat as well. The tests on the VMax were done at 3 different shops, on 3 different dynos, in 3 different parts of the country, and with 3 different cars....no tuning on any and all showed 20 RWHP and 25-28 RWTQ gains.
SC2150 is offline   Reply With Quote
Old 05-15-2012, 04:17 PM   #5
butters
butters's Avatar
Drives: 2010 2SS/RS L99
this had me confused at first as the LFX has a composite intake manifold, so no need for an isolator
butters is offline   Reply With Quote
Old 05-15-2012, 05:02 PM   #6
h2oplay
Winners find a way
h2oplay's Avatar
Well worth the money if you consider hp per $.....
Old 05-15-2012, 05:22 PM   #7
MACE_ENG
MACE_ENG's Avatar
Drives: LLT Machine
Here is a detailed thread to the question that you're asking.
http://camaro5.com/forums/showthread...highlight=mace
Hope this helps
Kindest Regards,
Steve
MACE_ENG is offline   Reply With Quote
Old 05-15-2012, 05:30 PM   #8
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
For LFX?
blackswan is offline   Reply With Quote
Old 05-15-2012, 05:43 PM   #9
MACE_ENG
MACE_ENG's Avatar
Drives: LLT Machine
Originally Posted by blackswan View Post
For LFX?
Doubt it :( But then again who knows
Old 05-15-2012, 07:08 PM   #10
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
If you want an unbiased opinion, here's mine.
2 cars in our camaro club have insulators. 1 an rx and another a mace. I personally took a ride in both... The difference could not have been more noticeable. The mace was amazing!! It pulled hard from 2400K up until redline. The rx wasn't bad but comparing the two, it was evident the mace was a killer buy. When the member with the rx took a ride in the mace insulated car, he decided to sell his rx. I'm not bashing a product and just telling you my experiences so take it for what it is. I personally don't even have an insulator but I'm actually ordering the mace tonight after seeing the difference between the two.
I'll even tell you that I was originally set on the rx because of the fit with my vararam but even if i have to do some modifications, I'll make it work. The Mace is that good. The vararam and mace are a match made in heaven
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 05-15-2012, 07:41 PM   #11
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
lscamaro, were the other mods, tranny, wheels, tires, etc. in the two cars similar? In other words, is it an apples to apples comparison other than the insulator?
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 05-15-2012, 08:36 PM   #12
lscamaro
lscamaro's Avatar
Yes sir. Both with injen long tubes. The only difference was that they had different axle-backs. Just those mods.
Oh and both rs package so same wheels and tires
Old 05-15-2012, 08:37 PM   #13
gahammerle
gahammerle's Avatar
OK, cool. Sounds like a good comparison then. I actually have both version sitting in a box, just waiting for some free time to install. I have toyed with the idea of stacking both.
Gordy
Old 05-15-2012, 09:08 PM   #14
drakedgar
drakedgar's Avatar
Thanks guys! I went with the mace 25mm!!
