TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment
Old 02-19-2024, 06:02 AM   #1
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
SOLD Mighty Mouse Gen5 XL Catch Can
**SOLD** Changing setups so I am selling this Mighty Mouse Gen5 XL catch can. It works like it should and has fittings for 6an lines. Includes the mounting clamp and bracket I used to mount it to the drivers side wheel well
Asking $OLD + the ride.
Name:  Screenshot 2024-02-19 at 5.55.37 AM.jpg
Name:  Screenshot 2024-02-19 at 5.55.43 AM.jpg
Picture of where it was mounted -
Name:  Screenshot 2024-02-19 at 6.01.11 AM.jpg
Name:  Screenshot 2024-02-19 at 6.00.51 AM.jpg
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 02-19-2024, 07:12 AM   #2
Carpetguy
Carpetguy's Avatar
Drives: 2011
Which one are you going with?If you dont mind me asking.
Just was looking at rx
Carpetguy is offline   Reply With Quote
Old 02-19-2024, 08:19 AM   #3
Ashen 6.2
Ashen 6.2's Avatar
Originally Posted by Carpetguy View Post
Which one are you with?If you dont mind me asking.
Going with the Motion Raceworks top loader billet can
Old 02-19-2024, 09:20 AM   #4
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
Is this a "wild" can that can be used with boost? I need a simple solution to run clean air to the drivers side valve cover and if this can has the 3rd port i may just be able to use it.
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is offline   Reply With Quote
Old 02-19-2024, 09:47 AM   #5
Ashen 6.2
Ashen 6.2's Avatar
Yes, this is what MM recommended for me to use with my S/C and it has 3 ports. I had 1 coming from each valve cover and then then one from the catch can to the intake just behind the throttle body.
Old 02-19-2024, 10:40 AM   #6
Anthony S
So you ran a normal oil fill, plumbed a line to each valve cover, and also capped the valley cover correct?
Old 02-20-2024, 04:31 AM   #7
Ashen 6.2
Ashen 6.2's Avatar
that is correct.
Old 02-28-2024, 05:20 AM   #8
Ashen 6.2
Ashen 6.2's Avatar
price drop to $150
Old 02-28-2024, 06:12 AM   #9
SlowLS1
SlowLS1's Avatar
Drives: 2010 Camaro SS , 2011 Colorado LS1
This is an excellent deal. I'm seriously tempted to pick this up. I already bought the AGP catch can but wish I'd bought MM instead. Someone needs to buy this before temptation wins over me.
SlowLS1 is online now   Reply With Quote
Old 02-28-2024, 07:52 AM   #10
HuZL1n
Drives: 2013 Camaro ZL1 Vert
If this will fit my 13 ZL1 I'll take it. I'll PM you my cell to work out details.
HuZL1n is offline   Reply With Quote
Old 02-28-2024, 02:42 PM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Buy this one and sell yours!! Problem solved!! lol.
Old 02-28-2024, 02:55 PM   #12
HuZL1n
I spoke to MM today and it will fit. I sent you my number via PM.
Old 02-29-2024, 04:20 AM   #13
Ashen 6.2
Ashen 6.2's Avatar
SOLD
