06-21-2018, 10:55 PM | #1 |
Drives: ISO ss 1le Join Date: May 2018
Trailer Tie Downs
Hi guys, question for you all who are trailering to the track. How are you tying the 6 gen camaro down on your trailers? My aluminum trailer has 4 tie down locations on the 4 corners and my last three cars (two M3's and a z06) have have the T hooks which get straight to the frame and the cars do not bounce over bumps. They are rock solid and I have never had a T hook budge on me.
With that being said, every time I have towed a car using wheel straps, i do not feel the car is as stable as it should be as i can feel the trailer bouncing from the cars suspension. I find that going through the wheels the straps tend to give a bit, and get loose over hours of driving... Has anyone tried the Zl1 addons tie downs? Seems like they make sense, however wanted first hand experience. They seem to serve the same purpose as a Thook straight the the frame. Before anyone recommends an Etrack, i don't have the ability to use an Etrack on my open aluminum trailer, and that still leaves the frame unloaded. Thanks in advance |
06-21-2018, 11:15 PM | #2 |
BAMF SS
Wheel straps on the front
Lower control arms, crossed, for the rear I'm one of those guys who dont like strapping down on the sprung weight of the car. Some people like loading the suspension down, but to each their own. Not my car, so they can put their car on their trailer with just a parking brake for all I care. Lol
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
06-22-2018, 08:16 AM | #3 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I'm in the same camp as danhr about not strapping down the sprung mass of the car. I'm planning to strap over the wheels similar to this one. In your case, since e-track isn't an option, you could maybe bolt a few d-rings or something to the trailer deck instead? Strapping over the wheels like that will be plenty stable and is how GM secures them on both trailers and boats. Strapping through the wheels or suspension might also be OK, but I'm personally trying to avoid it just because it's not as uniform for load distribution and has a higher risk of damaging the car and/or straps. I'm probably overly cautious when it comes to this kind of stuff, but I try to follow the OEM recommended towing suggestions whenever I can.
2017 SS 1LE.
06-23-2018, 05:58 AM | #4 | |
06-23-2018, 06:59 AM | #5 |
corner barstool sitter
Strapping to a control arm makes me uneasy because they're going to be moving every time the sprung mass moves. Just not as far.
I wouldn't even think of strapping to a control arm or other link that isn't itself carrying the suspension spring and/or shock. Seen where a link with location function only loaded like that somewhere along the line buckle at autocross (sending the wheel into a huge amount of positive camber). Norm
06-23-2018, 07:31 AM | #6 | |
Yanking a 10k strap down (especially crossed) on suspension or wheels can pull a car out of alignment quite easily. Seen it too many times. I wonder why Chevy took the T hook frame holes out of the 6th gen. All of my precious cars have had them and they are great and provide an even load across the cars. |
06-23-2018, 08:38 AM | #7 |
Drives: ZL1 1LE Join Date: Oct 2016
I've been using four wheel straps and it has worked well so far. I do check it every few hours to be on the safe side. I have the ZL1 tie down points as well, but the location of the front is impossible to reach and the rear came loose on me once.
06-23-2018, 08:53 AM | #8 | |
BAMF SS
06-23-2018, 01:48 PM | #9 |
