Roto-Fab
Old 08-31-2015, 11:43 AM   #29
JSure83
JSure83's Avatar
Drives: 2015 Camaro LS1
Originally Posted by woodside783 View Post
The only difference is the car has never lost power when doing this.
That's the thing: it happened as I was accelerating, so the power cut pretty drastically (it happened around 10pm last night).
One update though is this morning, the car is acting just fine now with no cut power and the only warning light being the check engine light. I couldn't get to an AutoZone before work, so I'm hoping to stop by after work (I have a meeting during lunch break). Again, there's no major vibrations so I'll update ya'll later tonight with the code that AutoZone provides and if resetting it clears it out.
I hate computers sometimes... haha
JSure83 is offline   Reply With Quote
Old 09-01-2015, 10:01 PM   #30
FastGirl
FastGirl's Avatar
Drives: 2013 2LT/RS
This happened to me…Dealership said the electronics in the gas pedal were fried…new gas pedal, and all good!…took the opportunity to upgrade to ZL1 pedals too LOL
FastGirl is offline   Reply With Quote
Old 11-25-2015, 11:52 AM   #31
Justav6-4reel
Drives: 2010 Camaro v6 full of aftermarket
Mine did this same thing! Use to say loose timing components until dealer reflashed my car. She started acting like she was gonna die, popping and all. After the flash it was back to ok
Justav6-4reel is offline   Reply With Quote
Old 12-04-2015, 01:05 AM   #32
Adam63impala
Adam63impala's Avatar
Drives: 63' chevy impalaSS , 12'Cam89'Cam
Mine has done this several times , and all of those times I had just backed onto my driveway and put it into park... I then parked on a level surface (my garage ) let it sit over night and all is well . I also remember right when I got the car three different times I got a service air bag message when I was driving ..hasn't done that in a couple years though ...
Adam63impala is offline   Reply With Quote
Old 12-07-2015, 09:33 PM   #33
CeeTee
CeeTee's Avatar
Drives: 2011 Black 1LS
Stabilitrak Service light, Power reduced... dealership days i have a short in the throttlebody.
CeeTee is offline   Reply With Quote
Old 12-07-2015, 10:41 PM   #34
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Got a vitesse throttle controller?
Caswell239 is offline   Reply With Quote
Old 03-24-2016, 01:10 PM   #35
MonSSterMaro
MonSSterMaro's Avatar
Drives: 2010 Camaro 1SS Inferno Orange
So my car was rebuilt recently. While it was being rebuilt, i did my own port and polish on throttle body, intake, cylinder heads, etc. After the rebuild, everything worked fine for two weeks until the a rocker arm broke apart. I got the engine power reduced/service stabilitrak. I fixed the rocker arm and the engine still runs good. But i still have the engine power reduced. My fear is that the throttle body is the problem (ill know later when i get the code read).
Is there any way to fix the throttle body as oposed to just replacing it?
Sent from my SM-N920P using Tapatalk
MonSSterMaro is offline   Reply With Quote
Old 07-10-2016, 10:02 AM   #36
BKinBLK2010
Drives: 2010 black 2ss 21 pollished
2010 RS SS 10000 miles on it and now it shuts off reading come up on dash engine power reduced
Help
BKinBLK2010 is offline   Reply With Quote
Old 07-10-2016, 07:48 PM   #37
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
Help
Hi BKinBLK2010,
I’m sorry to hear you’re getting the “Engine Power Reduced” notification in your Camaro, and I do apologize for any inconvenience this may have caused. Have you been able to bring this to the attention of your dealer? As they would be in the best position to diagnose this for you, I would be more than willing to offer you additional assistance with getting into contact with them. Please feel free to send us a private message if this sounds like something you’d be interested in moving forward with.
Kindly,
Angela O.
Chevrolet Customer Care
Chevrolet Customer Svc is offline   Reply With Quote
Old 06-01-2017, 10:55 AM   #38
Nasty1970
Nasty1970's Avatar
Drives: 2011 Red 2SS RS Convertible
this seems to be a generic light, it flashed my info center this morning, and immediately disappeared. I need to check the rear end components, plugs, wires. I don't think my issue is related to the throttle body, as mine didn't go into limp mode.
I still need to do the rear brakes, so maybe that is the issue.
[IMG]
<a href=http://i683.photobucket.com/albums/vv198/nacogdochesjaycees/20161112_121016.jpg target=_blank>http://i683.photobucket.com/albums/v...112_121016.jpg</a>
[/IMG]
1970 Camaro ,2011 Red Convertible 2SS,2008 Saturn Sky,2012 Jeep Wrangler
Nasty1970 is offline   Reply With Quote
Old 10-31-2017, 11:16 AM   #39
Camaro zl1 transfer
Drives: Chevy camaro 2012 1lt
Hi i have a chevy 2012 checy camaro 1lt i have cold air induction air intakeand high flow cats(from solo performance) on it and it was flash tuned by trifecta performance tune but now the car check engin light is on with a code p0113-00 p0151-00 p0300-00 p2228-00 po15b
i have already replaced the o2 sensor but it wont go off and car wont even pass inspection plus it is hesitating when accelerating and is sounding wired then it used to
also I got "service stabilitrak," traction control turned off, "reduced engine power," and the check engine light came on. Could barely drive the vehicle
WHAT SHOULD I DO
Camaro zl1 transfer is offline   Reply With Quote
Old 12-05-2017, 01:28 PM   #40
Nasty1970
Nasty1970's Avatar
replaced battery, it gave me a little crap starting the next day, so I took it in and sure enough bad.
Also cleaned throttle body, it had a fair amount of carbon build up. More than it should in my opinion. I also ran a can of sea foam through gas.
no more stabiltrack messages, but I still have a miss.
[IMG]
[/IMG]
Old 12-03-2021, 10:45 AM   #41
Alo097
Drives: Chevy camaro LT
service stabilitrak and engine power is reduced, car won’t start
Hello, I’m new here I’m stumped with this issue
I have a v6 2012 140k and I’m having same issue only my car won’t start and completely shuts off it feels like it misfires i took it to the dealership they said it was the ECM they got the new part it turned back on I took it home when I was turning on to my street I accelerated (pretty hard)and the car turned off on me again all the lights came back on I already paid $800+ And I can’t really figure out what it could possibly be the lights work and dash lights come on but won’t start so I doubt it’s battery. Also 2 weeks before car turned off on me while driving for the first time i would accelerate hard and it would misfire and the engine light would come on flashing then go away seconds later Any ideas ?
Alo097 is offline   Reply With Quote
Old 02-08-2022, 06:38 PM   #42
orcuttg
Drives: 2010 Camaro SS
I got this error after getting my battery replaced at interstate. I let them use the battery backup to keep the vehicle powered while they change the battery, I knew I shouldn't have let them plug it into the obd port. It blew the 7.5 volt f2 fuse.
I should have trusted my Spidey Sense and not let them do such a backwards way to keep the vehicle powered.
2010 Camaro SS
Built by M2K Motorsports, tuned by PatG
BMR Level 3 suspension, Pedders XA Adjustable coilovers
LS3 block stroked to 427--forged pistons, Molnar rods, stage 2 cam, McLeod RXT 1200 clutch, Kooks headers, Comp Cams pushrods and rockers, RotoFab CAI
orcuttg is offline   Reply With Quote
engine power, stabilitrack, throttle body, tps
