08-07-2014, 03:09 PM | #1 |
Livin' the Dream
Drives: '23 Charger GT, '23 Stingray Join Date: Mar 2013
Road Debris vs Factory Protective Film
I've posted before about how terrible the GM Aftermarket Splash Guards are at protecting the rear quarter panels.
The first picture below is of the factory protective film all chewed up from road debris. Only a few of the gouges went into the paint so the film did its job. In the last 3 pictures... I had the film replaced with a bigger piece that goes from the seam, to the door gap, and to the line of the wheel well so you can't see the edge of the film like the factory film. Then installed RPI's ZR7 Stage II Side Skirts for even more protection and give the car a subtle yet more aggressive look.
If you spell Chuck Norris in Scrabble, you win. Forever. Last edited by Hulkamaniac; 08-08-2014 at 12:44 PM. |
08-07-2014, 08:39 PM | #2 |
asptroopa1
Drives: 2014 Corvette Join Date: May 2013
I agree...mine looks all chewed up too.....maybe ill be buying something like that too...yours looks good Z-51......I also found out that Chevrolet will not have the protective film all over the C-7 in 2015 as mentioned it was taken off the option list today
08-07-2014, 10:35 PM | #3 |
Drives: Z51 White on Black Join Date: Jun 2014
What exactly do the side skirts do, do they repel stones and rock? I have the RPI splash guards in matched color look subtle but nice.
How about install of the side skirts, do yourself project? What is the difference between the Stage I and the Stage II, I saw both but can't tell difference |
08-07-2014, 10:53 PM | #4 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Side skirts look good and also,protect the side. They sacrifice themselves as they do get dirty, bout 2x as dirty as the car. They go on with hand tools and can be DIY, IF you feel comfortable drilling the center or using tape correctly. This is the Lashway street skirt-carbon flash, then cquartzed and edges xpel'd.
08-08-2014, 07:48 AM | #5 |
Glen looks sharp, do you know the difference between this and the RPI stage i and 2, can't tell what the difference is, looks very close except for material
08-08-2014, 08:28 AM | #6 |
Drives: 1974 & 2014 Corvette Stingrays Join Date: Mar 2013
Dada, if you look real close at the RPI photos, you'll see that their Stage 2 skirts are very much like Lashway's. On both the outer edge is a straight line from front wheel opening to rear wheel opening. RPI's Stage 1 skirt tapers in a little as it goes front to rear and flares back out for the last foot or so. They will all attach to the car in about the same manner. The Stage 1 skirt will probably allow an easier time getting in and out of the car without scuffing up the finish, tho it may not protect from road debris quite as much. It will still protect far better than no skirts at all.
08-08-2014, 08:41 AM | #7 | |
08-08-2014, 09:38 AM | #8 | |
Livin' the Dream
The ZR7 Stage I side Skirts follow the contours of the sides of the car. See picture below. The ZR7 Stage II go from outside edge of front fender to outside edge of rear quarterpanel and help with aero and used for racing. It is a two-man job since they are so long. They screw right into the lower rockers with self-tapping screws. I also used 3M tape where they went underneath the rockers. Our Club had a cook-out in Dysart last night and HWY 21 just had all its cracks and holes filled with tar and pea gravel. 47 mile round trip and NOT ONE rock chip or mark on the rear quarters. In my book, RPI Designs NAILED IT!!! I normally don't condone drilling or putting holes into any car, but these were definitely worth doing that!!! I highly recommend them!!! Below these two photos... Factory Protective Film vs the Aftermarket Film As you can't see, the aftermarket film goes from the door and body panel seams to wheel well edge and rocker panel. Better coverage and no visible edges. Not to mention after 47 miles on the pea gravel repaired road... NOT ONE rock chip or even mark.
If you spell Chuck Norris in Scrabble, you win. Forever. Last edited by Hulkamaniac; 08-08-2014 at 12:20 PM. |
08-08-2014, 11:18 AM | #9 |
This is great info, I noticed those very seams when I got my car. It seems like the RPI ones are the way to go but I won't know how to install them, will need to find someone. I have the RPI splash guards which I was able to do myself very easy
If I have the RPI guards that are held together by that bolt underneath the quarter panel, can I still install the skirts? |
08-08-2014, 12:11 PM | #10 |
Livin' the Dream
I went to the dealership to put my car up on a lift to install mine.
My buddy sent one of his body techs to help cuz the pieces are so long. You can do it in your driveway, on or off jacks. But having it on a lift is so much better. Holes are pre-drilled on the skirts so all you do is put the screws through the holes and into your rockers. Get some 3M automotive tape too. Don is the gentleman you want to talk to at RPI. Use coupon code RPIDON to get free shipping and 10% off the price. 888-257-8515
If you spell Chuck Norris in Scrabble, you win. Forever. |
08-09-2014, 09:44 AM | #11 |
Drives: '19 ZR1 Shadow Gray & '16 Z06 LBR Join Date: Jul 2010
Dada...there is a youtube vid about the installation of these. Just search C7 Corvette side skirt installation.
Z51 Stingray...thanks for the coupon tip. Ordering today...still trying to decide - Stage I or Stage II. I thought that I had mind set on the Stage II for the added protection and then I looked at how the Stage I kind of follows the design of the car. Did you get the painted ones? It doesn't seem like there would be much difference in appearance between the flat-black and the unpainted. I guess I should give Don a call. |
08-09-2014, 10:03 AM | #12 |
Livin' the Dream
I got the painted ones in Carbon Flash Metallic to match all the vents, stinger stripe, mirrors, and spoiler.
I'd recommend you going with the Stage II's. They'll offer more protection and give your car a nice, subtle aggressive look.
08-09-2014, 11:17 AM | #13 | |
Just curious - did you get the larger piece of paint protection film from RPI also? |
08-09-2014, 02:37 PM | #14 |
Livin' the Dream
The owner of a local shop here in town came out and did the vinyl film.
Thread Tools | |
