02-12-2013, 05:29 PM | #1 |
MIC
Drives: 2012 SSRS 6sp man Blk Join Date: Nov 2009
gauges
I am having a whipple installed by a well known shop and I'm wondering if gauges(boost,fuel) are necessary. I will be around 550+ whp. Obviously I.m probably being cheap.
Looks like it would be $300 or more to do it. |
02-12-2013, 05:31 PM | #2 |
Drives: 2SS RS Join Date: Mar 2010
I don't have any either but want some. I'm sure they're good to keep an eye on things. In the interim, I bought the ultragauge after reading a few reviews here about it. Do some searching here on this one if you're interested.
http://www.ultra-gauge.com/ultragauge/index.htm I parked the car for the winter before getting to play with it very much.
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
02-12-2013, 05:36 PM | #3 |
Stroked and blown
I too was wondering about boost/fuel guages. I cant imagine you really need them but they do look nice. I have never been driving and wondered how much boost or fuel pressure am i at right now. Now, I do know how much boost and fuel pressure my car runs at because it spends way too much time on the dyno jet.
LME 416 LS3 shortblock/Callies Compstar 4340 4"crank/Callies 6.125 H beams rods/Wiesco 4.07 forged pistons/Cam Motion custom LS1/LME ported heads /maggie TVS2300/I West 8rib 10%OD /3.2 pulley/OD cog drive/JRE tensioner/ID850 /ADM dual fuel/Kooks LT 1 7/8/magna flow2.5 /cat delete/Roto Fab CAI /MGW short throw /SPEC super twin clutch/G Force built trans,carbon syncro rear shaft upgrade /DSS 9"single CF DS /Strange 3.70/31 spline trutrac/MT DR's/earls oil cooler /tuned KHC
02-12-2013, 05:50 PM | #4 |
Hasbin of Stock Bottom HP
Look at getting an ultra gauge it can read boost off the obd if you have a zr1 map sensor and it also reads fuel pressure and bunch of other stuff. Only like 60 bucks
02-12-2013, 05:58 PM | #5 |
Not needed, I just put an A/F gauge in so i could data log it, and since the pillar had 2 holes added a Boost gauge. Boost gauge is pretty much worthless, you can data log without it. Other then that they just look cool.
02-12-2013, 05:59 PM | #6 | |
MIC
02-13-2013, 03:16 PM | #7 |
Drives: 2011 Camaro SS/RS Join Date: Feb 2011
Im getting my supercharger as well pretty soon. 4 days actually. Pretty new to the supercharger thing as well, what exactly will i be looking at when i am looking at the gauges, i proabably be getting one for boost psi and Air to fuel ratio. I will be running whatever boost comes standard with the slp supercharger, i dont want to push it too much right now.
02-13-2013, 03:45 PM | #8 | |
MIC
02-13-2013, 05:37 PM | #9 |
Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
I'd say mostly for looks but they do come in handy from time to time. +1 on the ultra gauge. I run that and A/F & boost.
Ultra gauge you can setup alarms which is pretty cool.
02-13-2013, 06:06 PM | #10 |
02-13-2013, 06:11 PM | #11 |
Drives: '11 SW 1LT RS Join Date: Aug 2012
You guys should take a look at dashcommand on the iphone. I used a OBD ii bluetooth and a little iphone mount. It will show you just about anything and does much more than I need it to. It will data log and everything. I think it is way under used on the site. It is a much cheaper fix and pretty cool to play around with. It has some pros and cons like anything.
02-13-2013, 06:20 PM | #12 |
It will not. But for $60 I think it does quite a bit.
02-13-2013, 08:12 PM | #13 |
Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
I have the ADM gauges for boost and air fuel. They look stock and the best setup I have seen.http://admperformance.com/products.p...51&product=251
