10-17-2013, 08:32 AM | #29 |
Drives: 2SS RS Join Date: Sep 2012
I took it to the shop because I thought it would be a simple fix, I thought wrong. Right now I think its either it being caused by water damage (resolved through insurance). if thats not the case I might have a warrantee claim. It could go both ways I might have to go out of pocket both ways.
10-17-2013, 08:56 AM | #30 |
Drives: none (yet) Join Date: Jul 2012
maybe a ls7 upgrade in the future?
10-17-2013, 09:06 AM | #31 |
36.58625, -121.7568
This guy seems to have the right thought process
10-17-2013, 09:08 AM | #32 | ||
Drives: 2017 2SS Join Date: Mar 2012
Warranty is for a factory parts defect or failure. What the OP is describing is really no different than having an accident, and sustaining serious damage. Warranty does not cover that either. As mentioned, this is why you have insurance.
1996 Corvette - LT4
2017 Camaro 2SS 2019 GMC Sierra 2500 HD 2015 Harley Davidson Ultra Limited |
10-17-2013, 09:17 AM | #33 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
Unless of course the damage was caused by the lifter dropping, in which case if he falls within the VINs affected by the lifter TSB then he would be covered under warranty.
10-17-2013, 09:30 AM | #34 | |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Full of water, the combustion chamber is now solid. Can bend a rod, break a piston, bend valves, bend pushrods.... Push rods have become a bit stronger lately since the bendable LS1 days. Try to open a valve into a solid combustion chamber.... can break the lifter right out of the block. It's just thin cast iron in that area, the lifters, valves, PR's are steel. Water depth is only one factor. Basically have to be inching along to avoid a wave. Any speed at all and that wave your wide front tires are pushing will be a lot higher than you think. Those big wide 20s are going to push a big wave right into the intake, especially aftermarkeet ones. The OE intake has been trough tested to go pretty deep. Aftermarket ones... get dyno tested for hp, not water ingestion. With any aftermarket intake, you must drive around standing water. Some are worse than others, some are horrible. |
10-17-2013, 09:38 AM | #35 | |
10-17-2013, 09:38 AM | #36 | |
10-17-2013, 09:56 AM | #37 | |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
insurance co pay them direct 100%, less your comp ded and possibly some depreciation/betterment. Why would GM have anything to do with this ?
10-17-2013, 09:56 AM | #38 |
Drives: '13 Camaro 2SS/RS Join Date: Sep 2013
just curious, what intake did you have on the car? CAI, inc?
10-17-2013, 10:07 AM | #39 |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
I seriously doubt he has ours, our intake is sealed off more than any other aftermarket CAI available for this vehicle, and the filter stays in the stock location.
Most likely he has a long tube set-up or an open element system in which the water could have rushed up and over the open box. |
10-17-2013, 10:20 AM | #40 |
Drives: 2013 2SS Join Date: Mar 2013
Headers and no tune? Could that be the culprit?
10-17-2013, 10:35 AM | #41 |
10-17-2013, 10:38 AM | #42 |
Time for a 7.0L. I've been looking at putting this motor in my 2008 Avalanche LTZ.
http://www.ebay.com/itm/CHEVY-427-LS...73b8a3&vxp=mtr NEWCHEVY 427 (7.0L) LS3 LS6 LS7 LS1 LS2 L92 / 640 HORSEPOWER STREET / STRIPUPGRADE FUEL-INJECTED CRATE MOTOR!! 640 HORSEPOWER - 608 FT/LBS OF TORQUE
It's nice to have options.
