Roto-Fab
Old 03-20-2024, 03:04 AM   #1
Diablo4
Drives: 2011 Chevrolet Camaro SS A/T
Question Rear Knuckle Bushings ?
Is there any chance to find a replacement for the rear knuckle silent blocks? Maybe smb has a part number or link ?) I found racing kit for $600 but it's more expensive than the knuckle assy...
I have a slight backlash. At first I thought it was a wheel hub bearing, but it turned out to be a bushing
Diablo4 is offline   Reply With Quote
Old 03-21-2024, 09:58 AM   #2
Diablo4
No ideas ? )
Old 03-21-2024, 10:08 AM   #3
gtstorey
I think that is more than a simple bushing. I think it's a rubber covered monoball so it's not likely that you will be able to replace cheaply.
Old 03-21-2024, 10:28 AM   #4
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
It shows the bushing in the catalog but no part number or even able to buy it but for $185 a piece on rockauto I would just replace the entire knuckle, even if you find a bushing you'll have to remove the knuckle itself anyway to press out and replace it. Might not be worth all that work. That's just me though, good luck!
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 03-21-2024, 10:56 PM   #5
Diablo4
Yes, rockauto has entire assy. Thanks )
Old 03-21-2024, 10:57 PM   #6
Diablo4
I found kit for $600 only. Knuckle assembly is $187. I will replace assy
