TireRack
Old 02-21-2015, 03:07 PM   #1
CyberGreyConvertible
Dunder Mifflin Inc.
CyberGreyConvertible's Avatar
Drives: 2012 2SS/RS Convertible
Reversing key recall - will these roll pins work?
Im looking to reverse the key recall in order to get my switchblade key back. I just ordered two blank keys which fit the switchblade fob, and I'm looking to order the roll pins now.
I found these on eBay, will they fit?
http://www.ebay.com/itm/MIP-Hw-Pin-1...item4d28e8a986
I appreciate all input, thanks!
*** UPDATE: If anyone could give me the link to the correct-size roll pins, I'd really appreciate it! ***
CyberGreyConvertible is offline   Reply With Quote
Old 02-21-2015, 03:13 PM   #2
Trip
Trip's Avatar
Drives: 2015 White RS 2SS 1LE
They should fit through the hole but they'd be a little bit too long, you'd have to trim it for the key to close properly. If you're buying them off the internet, you might as well get the correct size. 1/16 x 5/16.
Trip is offline   Reply With Quote
Old 02-21-2015, 03:14 PM   #3
ChrisBlair
Buick 455 Fan
Isn't there more to it than just affixing the blade back on the mount?
Old 02-21-2015, 03:19 PM   #4
Coop1701
Coop1701's Avatar
Drives: 2014 Chevy Camaro SS
Not really..., I cut my old keys out of the plastic and stuck it in the old slots. I found two nails the size of the pin hole and trimmed them down to fit. Did both my keys in less than 30 minutes.
Number of people killed by wolves last year... Zero
Number of people killed retrieving change from a Vending Machine.. Six
Coop1701 is offline   Reply With Quote
Old 02-21-2015, 03:22 PM   #5
ChrisBlair
Buick 455 Fan
So there's no chip in the 'classic' key?
Old 02-21-2015, 03:28 PM   #6
ccb1975
ccb1975's Avatar
Drives: 2010 WHITE SS
I just took a hammer and busted mine up. Super glued it back into my fob!
ccb1975 is offline   Reply With Quote
Old 02-21-2015, 03:30 PM   #7
Dunder Mifflin Inc.
Can somebody link me to the correct-size roll pins? I've searched for the 1/16" x 5/16", but can't find anything online.
I'd greatly appreciate a link to them!
Old 02-21-2015, 03:32 PM   #8
Coop1701
Coop1701's Avatar
Nope and I used a chisel to get mine out. 4 wacks with a hammer on all sides. I just held the key tight against the blade of the chisel and all done. :-)
Old 02-21-2015, 03:36 PM   #9
Dunder Mifflin Inc.
Just came across this kit. So, these will work? It includes 1/16 x 5/16 pins.
http://m.harborfreight.com/315-piece...not%20provided
Old 02-21-2015, 03:37 PM   #10
ChrisBlair
Buick 455 Fan
McMaster-Carr knows all
http://www.mcmaster.com/#roll-pins/=w0dgr9
Old 02-21-2015, 03:47 PM   #11
Trip
Trip's Avatar
There is chips in all the keys, the recall version and the switchblade version. But usually nothing is required to get the old switchblade style working since the switchblade was used originally, the car should still have that chip in it's memory.
Old 02-21-2015, 03:49 PM   #12
Trip
Trip's Avatar
Yes, that's what I bought to do mine.
Old 02-21-2015, 03:54 PM   #13
Dunder Mifflin Inc.
Awesome, just ordered a box. Thanks!
Old 02-21-2015, 06:08 PM   #14
wayne watson
wayne watson's Avatar
Drives: 2014 camaro ss ,1967 chevelle ss,
i'm going to do the dumb thing and not have it done
wayne watson is offline   Reply With Quote
