Roto-Fab
Old 04-25-2015, 02:06 PM   #1
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
Livernois Dual pump tuning??
So I'll be installing the dual pump assembly this week. What if any changes need to be done to the tune as far as the fuel setting go?
scv_guy is offline   Reply With Quote
Old 04-25-2015, 03:43 PM   #2
avido
Drives: camaro ss\rs
if it provides more fuel pressure than the stock you need to check the fuel setting or you risk to run too rich.
i don't really know the chevy ecu's logic but usually if i set a xx m.sec. of injector aperture with more psi more fuel will be injected
avido is offline   Reply With Quote
Old 04-25-2015, 03:47 PM   #3
scv_guy
scv_guy's Avatar
When I bought the pump they it would need to be addressed in the tune, but they where no specific to what needed to be changed. Any input would be great.
Old 04-25-2015, 04:04 PM   #4
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Here is what I know. The fuel pump control module controls the pressure/flow of the fuel pump. Changing pumps without reprogramming the FPCM (like with ADM's unit) could make little or no difference without changes to the FPCM.
BUT if your current pump was dropping off fuel pressure at high rpms when the car was tuned (e.g. FPCM demanding 58psi but pump only flowing 50psi) and now the new pump maintains the proper demanded pressure than it could throw the tune off by running rich and hurting power output
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 04-25-2015, 04:31 PM   #5
avido
is the pump coming with the controller?
Old 04-25-2015, 04:33 PM   #6
scv_guy
scv_guy's Avatar
No the pump is a "drop in replacement" per Livernois uses the stock controller.
Old 04-25-2015, 04:43 PM   #7
avido
so, install the pump,check the lambda value then decide. ask your tuner about the values you read. which mods do you currently have in your car?
Old 04-25-2015, 05:36 PM   #8
scv_guy
scv_guy's Avatar
Mods:
Stock L99
Turbonetics kit
Meth injection
Cat delete w/ exhaust
70lbs injectors
Boost controller set to 10psi
I had the pump installed, and on the dyno I start at 58-60 but drop to 46psi by the end of the pull
Old 04-25-2015, 05:53 PM   #9
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
Is Livernois doing the work for you or suggesting this? If so, I'd certain heed their advice.
2018 Audi TT RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped).
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
2021 Charger Hellcat Redeye Widebody
Sold
USAFS197 is offline   Reply With Quote
Old 04-25-2015, 05:55 PM   #10
scv_guy
scv_guy's Avatar
I have not had a chance to speak to them yet, I'll be calling on Monday..
Old 04-27-2015, 01:08 PM   #11
Andy@Livernois
Andy@Livernois's Avatar
Drives: 1987 Buick Regal Turbo-T
is he looking at delta pressure? or rail pressure? If he's looking at rail pressure, is it with an actual gauge? Typically speaking the computer talks in delta pressure, so if it runs 58# of fuel pressure with 0 boost, and 0 vacuum, it will show 58# of fuel pressure on the log. However, add 10# of boost onto it and it will show 48# of fuel pressure. The pressure didn't drop, but the delta pressure did.
Andy@Livernois is offline   Reply With Quote
Old 04-27-2015, 01:37 PM   #12
scv_guy
scv_guy's Avatar
Andy thank you for the response, I called and spoke with James he really was not able to help.
This was all done via laptop, can you please explain delta pressure and what needs to be done to correct it?
Old 04-27-2015, 05:52 PM   #13
JamesZL1
JamesZL1's Avatar
Drives: 2013 ZL1 A6 Camaro, 2015 C7 A6 Z51
also interested in this post since I have had fuel pressure problems in my ZL1. My tuner said that my pressure is dropping into the 30# area. That was on the dyno and he had his laptop in the car with him. The car has went lean once already and I burnt the tips off of 3 plugs. Added a boost a pump and it was wired incorrectly and it fried my ECM, so I will not be putting that back in the car. Now I am looking for a stronger pump, but I don't need a squash system for 1400.00. Just looking for a drop in pump that will do the trick..please help!
Roto-Fab CAI, Texas Speed Headers, Texas Speed X-Pipe, Texas Speed LS3-B Blower Cam, Metco 9.10" Crank Pulley, Metco 2.5 Upper Pulley, ID 850 Injectors, LPE Ported Throttle Body, Alky Control Methanol kit, E2 Catch Can, 610HP / 608 Torque.
JamesZL1 is offline   Reply With Quote
Old 04-27-2015, 06:24 PM   #14
Andy@Livernois
if he is looking at delta pressure, there is nothing to correct, as the pump is maintaining pressure. 48# delta pressure + 10# of boost = 58# of actual fuel pressure.
