01-21-2012, 01:18 PM | #1 |
Drives: Black Join Date: Jan 2010
What year cts-v brakes fit camaro?
Wtb: ss or cts-v brakes.
2004-2007. Last edited by verboten; 01-21-2012 at 01:33 PM. |
01-21-2012, 01:33 PM | #2 |
Drives: 2011 2SS SGM Camaro Join Date: Aug 2011
Why would you want to but cts on your camaro
01-21-2012, 01:35 PM | #3 |
Drives: 2006 Silverado SS, 2009 G8 GT Join Date: Aug 2008
01-21-2012, 04:29 PM | #4 |
01-21-2012, 04:32 PM | #5 | |
01-27-2012, 12:59 AM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
01-27-2012, 01:00 AM | #7 |
02-06-2012, 09:08 AM | #8 |
I used the 04-07 CTS-V rear calipers on my 1SS. I only needed to do the standard flip on the bleeders and hard line. Additionally; I have not heard this mentioned before but the 04-07 rear calipers have to be notched for clearance as was the original SS calipers. I found it to be alot cheaper to buy these calipers than the much newer versions when the only difference is a factory machined notch.
02-06-2012, 04:46 PM | #9 |
Drives: 2011 2SS RS Join Date: Jan 2012
Can you post pics of where you notched the calipers? and did the rear CTS-V go on your front? original rotors or CTS-V rotors? Any other specs when looking for those calipers ie 17 or 18 inch wheel on the CTS-V?
Also Pete said "The rear calipers on the CTS-V and SS are the same" I asked that on another thread and Pete said they where 4 pots? Thanks trying to get this sorted and installed - Doug |
02-06-2012, 04:51 PM | #10 | |
Up front, the 2009 CTS-V 6 pot caliper is different than the SS 4 pot front. The CTS-V uses a larger front rotor. The CTS-V rotor fits on the SS hub and is required for use with the CTS-V six pot caliper. We used the 2009 CTS-V brake setup, because we had a fair idea they would be used on the ZL1. |
02-06-2012, 05:23 PM | #11 |
Ok I am almost with you on everything but if CTS-V rear are 4 pot and so are SS then why put the CTS-V rear calipers on the SS?
Thank you for your patience, I am sure I am not the only dumb one in class today. |
02-06-2012, 05:49 PM | #12 |
The ONLY reason to sway out the rear SS calipers for the CTS-V rear calipers is to match the color. It has or had nothing to do with function.
02-06-2012, 05:58 PM | #13 |
JusticePete, are the front 04-07 CTS-V 4 pistons the same/will they fit on the rear?
02-06-2012, 06:59 PM | #14 |
Similar Threads | ||||
GT5 Camaro pics | brantley847 | Camaro Photos | Spyshots | Video | Media Gallery | 93 | 05-27-2013 08:35 PM |
Think about this and the Z28 5th gen | 13F20 | Camaro ZL1 Forum - ZL1 Specific Topics | 41 | 09-04-2010 12:59 AM |
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
