05-20-2022, 01:47 PM | #1 |
TPMS Bypass
I ran the search and can't believe this hasn't come up before. I, like most on here, have two sets of wheels for my Camaro. I'm tired of tire monitors. I had a plan to put all 4 in a PVC pipe, pressurize it and put it in the trunk. Been dragging my feet on doing it just because I would have to get the monitors out of my current stock rims or buy new ones.
Well the time is now. I have had my 2010 since it's birth and one of the TMPS has finally died. So I thought time to do a delete. As I'm messing around on the internet I found a little box, called a TMPS Bypass. I pulled the trigger and ordered it. Seems to easy if it works. Set up is a push of the button a few times and then just throw it in the glove box. Once I get it I will post pics and a little summary of how good it works or doesn't work. More to come! |
05-20-2022, 02:04 PM | #2 |
05-20-2022, 03:55 PM | #3 |
It don’t come easy.
Subscribed!
05-20-2022, 05:36 PM | #4 |
Oh nice! Sounds too simple but looking forward to the review.
05-20-2022, 06:58 PM | #5 |
Subbed !!!
05-20-2022, 07:49 PM | #6 |
Wouldn’t it be easier to buy some Tpms sensors for the extra wheels and call it a day. I also have two sets, both with tpms sensors.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
05-21-2022, 07:07 AM | #7 |
waiting at the tree
I just press the button and live with the dash icon.
If you think the Camaro system is screwed try the Pontiac G8 reset Like I said the icons nots so bad.
2010 2SS/RS A6 ZL1 Rims
05-21-2022, 11:55 AM | #8 |
^^^ This is what I did. They don't cost that much to buy..
05-23-2022, 10:04 AM | #9 | |
https://tpmsbypass.com I have tried it, it doesn't work in 2010 Only Camaro 2013-2020 are compatible with this box.(Sales & Customers Support SRSDRIVE LTD - TPMS BYPASS) https://www.ebay.com/str/futurzenith I have tried this too, it doesn't work in 2010. I'll try this next. https://spooftpms.com/us-gm-1-family-tpms-simulator/ Last edited by chevy pilot; 05-23-2022 at 12:08 PM. |
05-24-2022, 11:24 AM | #10 | |
This part is compatible with 1 vehicle(s) matching 2010 Chevrolet Camaro SS Coupe 2-Door 6.2L 6162CC 376Cu. In. V8 GAS OHV Naturally Aspirated. Compatibilities are defined by the seller for vehicles typically fitted for operation within the original listing country. Figured to good to be true..... |
05-24-2022, 11:44 AM | #11 |
05-24-2022, 12:46 PM | #12 | |
Instagram: Mr2Hard2See
Drives: 2011 2SS/ RS Join Date: Apr 2018
Here’s the extra long blk valves that was on before. Now here’s the new replacement sorry this pic is not a close up but you all should get the idea. It completed the look now I’m just waiting to see if someone can come up with a fix.
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242 BTR dual springs pushrods lifters retainers etc Che bronze trunnion Ls3 timing/valley cover Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers |
06-05-2022, 03:20 AM | #13 | |
06-06-2022, 01:11 PM | #14 |
So far so good.... I bought the one linked below from ebay and a battery pack from Walmart. It was super easy to set up, zip-tied together, and put it in the glove box. It shows all 4 tires at 34PSI. The next day it was still good. Drove it again a few days later and still holding. I have just been driving around town, so I figure the real test will be going to Kentucky. Well would NOT recommend. After 10-15 miles the system rest and the tire late came back. I will say it worked for just going around town fine. I’ll be returning for a refund.
https://www.ebay.com/itm/16284479844...ally+Aspirated Last edited by Lnch Mny; 06-12-2022 at 05:55 PM. |
