Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 07-23-2015, 07:16 PM   #1023
Red2014SS
Red2014SS's Avatar
Drives: 2014 2SS/RS Camaro
Originally Posted by krisprz2010camaross View Post
People who aren't having problems... Is your Camaro your daily driver?
I drive mine everyday. If I recall correctly. you had problems because of your BBK intake. I think the vendor even addressed your problems in a thread. I don't know why you always bring it up, because your other mods were responsible. They were incompatible with the VTC.... VTC even told you as much. Yet somehow, you always leave that out of your posts about the VTC.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH
Red2014SS is offline   Reply With Quote
Old 07-23-2015, 07:20 PM   #1024
clashley1976
clashley1976's Avatar
Drives: 2011 Camaro 2LT RS M6
This brings up an interesting concern. What sort of thing might be incompatible with a VTC? Pardon me if this has been hashed out already, but I'm uninitiated.
Sent from my SM-N900V using Tapatalk
-Cameron Lashley
Albany, GA
2011 Camaro 2LT/RS 3.6L M6 Summit White w/silver rally stripes
CAI intake, VTC, VMax PTB, VMax Iceolator, Apex intake scoop, Roto-Fab washer bottle relocate
Build Journal: http://www.camaro5.com/forums/showthread.php?t=419992
clashley1976 is offline   Reply With Quote
Old 07-23-2015, 07:26 PM   #1025
Red2014SS
Red2014SS's Avatar
I'm not sure. I think it's mostly aftermarket throttle bodies. I know with Krisprz, it was his BBK 102mm throttle body. He also had problems because he hadn't connected the throttle sensor wiring properly (to the throttle body). The vendor bent over backwards to help him and even ended up responding publicly in a post. He always seems to forget those details. You can't expect Vitesse to test the product compatibility with every mod on the market.
Some people have had legit problems with the product causing CELs. Most haven't. From what I've seen, if you are one of the unlucky ones, you just remove the VTC and get a refund. No damage is done. 95% of people who install it never have any issues.
Old 07-23-2015, 07:29 PM   #1026
clashley1976
Ok. I have a vmax PTB on my wish list. Don't think I've seen any complaints about that one. I've got an LLT.
-Cameron Lashley
Albany, GA
Old 07-23-2015, 07:37 PM   #1027
Red2014SS
Red2014SS's Avatar
If I were you, I'd email VTC and ask if there are any issues using the vmax and VTC together. To be honest, I think that once you get the VTC, you won't want the vmax anymore. Throttle response with the VTC is insane.
Old 07-23-2015, 07:39 PM   #1028
clashley1976
If I were you, I'd email VTC and ask if there are any issues using the vmax and VTC together. To be honest, I think that one you get the VTC, you won't want the vmax anymore. Throttle response with the VTC is insane.
Well, I've got a VTC on the way. Still want a CAI intake, though.
-Cameron Lashley
Albany, GA
Old 07-23-2015, 07:43 PM   #1029
Red2014SS
Red2014SS's Avatar
Can't wait to see your response once you install it. The install is pretty simple, but calibrating it is aggravating. I think it took me about a dozen attempts to get it properly calibrated. It's a pain in the rear. That could also be why some people have probs.
Old 07-23-2015, 07:48 PM   #1030
clashley1976
Good to know. I can handle that, as long as I know what to expect. Will definitely post my feedback once I get it installed.
-Cameron Lashley
Albany, GA
Old 07-23-2015, 09:17 PM   #1031
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
Ok first off, I'm just saying my experience with the vtc. Did I say it was bad? No. Did I say not to get it? No. And go back and look at my thread I said I THOUGHT it was my throttle body. The vendor assumed that it's incompatible and maybe or maybe it isn't. He would not know unless he actually had my car with him to see. Vtc is an amazing product, but just not for me I guess. And also you know what else I left out in my original post? After pushing in the throttle body cable in the throttle body and heard the click the next day I connected the vtc back and recalibrated it correctly(I am sure 100%) and everything was fine, but later when I was going back home I got a reduced power mode and cel again. Hmm what else do you have to say now? I didn't say anything cus I was already set in sending it back which I did and they have great customer service. For some reason you are still in denial that just because people have problems with the product you have it won't happen to you. And maybe it won't, but I am telling my experience with it and I'm not saying don't get it. To each their own.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 07-23-2015, 09:25 PM   #1032
krisprz2010camaross
Bbk intake wtf??
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 07-24-2015, 05:41 AM   #1033
bleavens1962
Drives: 2014 1LS Camaro
If you haven't had any problems with your VTC, great it is a fantastic mod WHEN IT WORKS . Hell, you may never have problems with it. If you get problems with your VTC don't be at all surprised (takes about 6-7 months). If an opinion is expressed here questioning the quality of the VTC,or the issues they have had with it, no one needs to get all butt hurt if they disagree.
bleavens1962 is offline   Reply With Quote
Old 07-24-2015, 09:48 AM   #1034
1Canuck
1Canuck's Avatar
Drives: 2014 2LT RS
perhaps for you 6-7 months but others are sooner after installation.
repairs/replacements have been made to show some are the issue. others have issues that go away after repair/replacement. Yet the vast majority have not reported any issues suggesting the device is mostly not an issue, just a smaller amount are an issue or cause an issue. as long as Vitesse continues to replace with success it is a great mod.
1Canuck is offline   Reply With Quote
Old 07-24-2015, 01:49 PM   #1035
bleavens1962
It is a great mod unless you get the "reduced power " on the interstate
Old 07-24-2015, 02:01 PM   #1036
1Canuck
1Canuck's Avatar
Drives: 2014 2LT RS
getting reduced power at any time sucks. did that actually happen to you because it would be a first I heard. so if it did happen to you detail how it went down. remember just the facts
