10-17-2012, 10:32 PM | #1 |
Untamed Performance EPT
Drives: 2011 2SS Join Date: Aug 2012
help vacuum leak!
Tuner says I have a bad vacuum leak.I searched all over for a diagram of stock vacuum system on my LS3 without any success. Can somebody describe the locations or even better a diagram.
Much appreciation!
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK 9in. diff with 4.11's, DSS Axles, and Alum Shaft Hurst Short-Shifter; Ideal Garage Master Cylinder H-E Street Slayer Twin Billet Clutch BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings. Strange Rear Coilovers and mounts Tuned by Rhino79 |
10-18-2012, 08:11 AM | #2 |
Drives: '69 SS Convertible Join Date: May 2009
Do you happen to have an oil catch can installed?
I had a vaccum leak once and it was due to my catch can drain plug not being closed all the way.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
10-18-2012, 08:30 AM | #3 |
Drives: 2012 2SS CAMARO 45th Join Date: Apr 2011
In your sig it says you have an Ideal Garage master Cylinder. Start there, make sure the vacuum line didn't pop off and follow some of the lines.
10-18-2012, 08:35 AM | #4 |
get some carb cleaner or something and spray it on the vacume lines while its running. you'll hear the idle change when you find the leak.
10-18-2012, 10:17 AM | #5 | |
I'll take a look at the master cylinder
Night Fury Cam
10-18-2012, 04:12 PM | #6 |
Need some help folks. Location of lines if possible.Thanks!
Night Fury Cam
10-18-2012, 04:34 PM | #7 |
synergy2011
jre told me the same thing that i have a leak somewhere and i have no leak and he said a vacuum leak or exhuast leak is causing low mpg
2011 synergy green ss/rs,rally stripes
09-22-2013, 12:09 PM | #8 |
Drives: 2010 Victory Red 2SS Join Date: May 2012
Same problem here folks, JRE says I have "a really bad vacuum leak" and I can't find it.
Anyone have a diagram?
My build thread (warning, use safari/chrome, FF doesn't like this many images)
http://www.camaro5.com/forums/showthread.php?t=265476 My Camaro with the Memphis Belle! http://www.camaro5.com/forums/showthread.php?t=267316 |
