04-06-2017, 01:35 PM | #1 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
To pull the trans or not
So my car has been on stands for 18 months for an engine build. Motor is ready to get dropped in. Will it be easier for me to go ahead and drop the trans with a low lift trans jack, then re-install when the engine is in? Or should I just leave it in, level it out and fight to make sure the engine and trans mate right? 2012 M6.
04-10-2017, 11:39 AM | #2 |
Bump
04-10-2017, 12:53 PM | #3 |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
I left the transmission in when I pulled and reinstalled my motor. You might have to loosen the crossmember a little but that would be it.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
04-10-2017, 03:06 PM | #4 |
