TireRack
Old 09-29-2015, 10:58 AM   #1
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Pulling the LS3 out through the top
Anyone here pulled the motor with cherry picker vs dropping the entire cradle? I don't have a lift and I am starting a swap in the next couple weeks just want to make sure I am not setting myself up for failure
Bildo is offline   Reply With Quote
Old 09-29-2015, 11:05 AM   #2
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
Out the top is the way to go. Very easy.
Get the TPIS Happy Hooker Lift Plate - made it a lot easier http://www.tpis.com/parts/view/67
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 09-29-2015, 12:22 PM   #3
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
YUP! Didn't even have to pull the hood.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 09-29-2015, 12:26 PM   #4
Bildo
Bildo's Avatar
Did you leave the trans attached?
Old 09-29-2015, 12:33 PM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
On 5th Gens out the top is easier, its not like a 4th gen where out the top is nearly impossible.
vroomapunk is offline   Reply With Quote
Old 09-29-2015, 12:33 PM   #6
JANNETTYRACING
JANNETTYRACING's Avatar
Automatic yes and leave the trans in the car.
Manual Pull the trans and clutch first, then pull the engine.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 09-29-2015, 12:48 PM   #7
SNSSTR
SNSSTR's Avatar
I just supported the trans from underneath and left everything connected from the transmission back. Pulled out complete engine minus headers and intake manifold. Came right out the top with no issues whatsoever.
Old 09-29-2015, 01:21 PM   #8
Bildo
Bildo's Avatar
Thanks alot everyone !!!!
Old 09-29-2015, 01:49 PM   #9
BenningJ
BenningJ's Avatar
This is exactly what I did and left the clutch/pressure plate attached to the motor.
Old 09-30-2015, 05:54 AM   #10
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
I left the trans in and pulled from the top. if i had to do it again id pull the trans 1st. Its a pain getting it back in with the trans in there.
Old 09-30-2015, 08:50 AM   #11
SNSSTR
SNSSTR's Avatar
I don't know about that. Wasn't much of a pain getting my engine to slide onto the trans.
I'd much rather slide the engine onto the trans than pull the exhaust and transmission (and reinstall) while my car is on jack stands in the garage. I've done it before by myself and it SUCKS.
