11-10-2016, 09:33 PM | #1 |
HARD WORKING PATRIOT
Drives: 2011 CAMARO 2SS RS-AUTO Join Date: Oct 2010
resolved.
Resolved.
11-11-2016, 10:40 AM | #2 |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
Text me.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
11-20-2016, 01:19 PM | #3 |
Drives: 2011 SS 6MT Join Date: Jun 2015
Any update on this? Trying to find the part numbers for all if these.
11-22-2016, 07:02 AM | #4 |
I just did a zl1 differential swap on my 2014 SS.
The original bolts were the torx end style... The ZL1 bolts (larger bolts) were Hex style, according the the ZL1 swap instructions.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.) |
11-25-2016, 11:43 PM | #5 |
I got my bolts in for my 2011. They were also not torx.
11-26-2016, 01:06 AM | #6 |
Hell I'm running Mercedes bolts in mine lol.
03-27-2017, 07:35 AM | #7 |
Drives: 2013 Camaro SS LS3 Join Date: Jun 2015
I have a '13 and purchased a replacement bolt from Gm that has a normal head instead of the hex head mine came with. It has the same thread and was told by the parts counter that they must have changed design.
Romans 5:8 But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. -Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20. |
