12-21-2013, 01:26 PM | #1 |
CCFL lighting issue
I have CCFL foglights and they are building a caramel like crust inside on both of them. So then one of them starts not working. Question.
Is that normal ??? and if so what can I do to fix them ?? I've had these foglights installed less than a week. There has been no water near it. (my car is filthy) so what can it be that is causing this ??
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
12-21-2013, 02:00 PM | #2 |
something was shorting out/ overheating and melted the housing
Killed so many water bottles that day...
12-21-2013, 02:02 PM | #3 |
The inside of housing was 8K HID bulb that was included in the kit.
Specs
12-21-2013, 04:58 PM | #4 |
Drives: 2013 RS - 2013 2SS/RS - 1971 RS Join Date: Sep 2012
imho 8K is too much heat without venting the housing. how many watts is the 8K bulb I believe most people are running the 4300K at 6 watts to match it up close to the HID some maybe running the 11 watt bulbs
12-23-2013, 12:04 PM | #5 | |
Those 8K HID bulbs were gotten from the same distributor. I did not get them elsewhere. So I don't know what else it could be. and if the bulb did it then why wasn't it burned evenly ? It was only burned on top. Not all over.
Specs
