07-31-2014, 11:11 PM | #1 |
'It's an experiment'
BMR and JDP -- Great Combo (LOTS of Pics)
After my 'saga' with the TSP underdrive pulley, it became obvious to me that I needed to follow my plan I initially set out to do -- bolt on HP upgrades then, suspension. I wanted to do a 1LE/FE4 upgrade to my 2011 2SS. BMR and JDP Tyler helped me get where I needed to go. I still have a couple of other upgrades to do (bushings and Toe Rods), but the primary updates are done.
I went with BMR sway bars (front and rear), Adjustable trailing arms and bushings, 1" lower front and rear springs, the FE4 upgrade (OEM lower control arms and sway bar links). All I can say is the change in the 'feel' of the car is amazing. I still need to get a 4 wheel alignment, but wow, does the car feel like its on rails. JDP Tyler really worked with me to understand what I needed based on my goals. BMR directed me to work with JDP and their combined info/suggestions really helped me get what I was looking for. Great service -- especially JDP Tyler. The OEM FE4 update was very simple to do. I would suggest anyone wanting to do these upgrades get all the parts first. I had mine in stages and began to realized I would have been better served to do it all at the same time (the lower control arms were 'removed' a few times ;o)... I did all of these upgrades myself with no 'other' help outside of phone support from JDP Tyler. I did run into an issue with the BMR Trailing arms being 3/16 too narrow, but Harbor Freight to the rescue! Got this gem to 'spread' open the back bracket of the trailing arm to fit: 5 seconds and all was well with the world! Below are pics of the parts installed. BTW, the OEM lower control arms are similar -- except where the sway bar links are for the 2012 +. I updated my 2011 to use the 2012+ rear sway bar/links -- and boy what a difference. I did have to drill the sway bar link hole to 12MM on the strut -- not a problem -- to support the 1LE/FE4 upgrade. Pics: Front: Sway Bar: Sway Bar and Links: 1LE/FE4 Sway Bar Link (BIG difference in roundness!): Front springs: Rear Sway Bar and Links: OEM 1LE/FE4 Lower Control Arm with Spring: Assembled Left Rear: Rear Lower Control arms -- Left is FE4 update, Right is 2011 SS OEM: Trailing Arm with Bushing installed (Left Rear): Adjustable! Trailing Arm with Bushing (Close up): BMR boxed goodies (Front and Rear Sway Bars for 1LE/FE4 upgrade) -Don Last edited by hammdo; 07-01-2017 at 03:41 PM. |
08-01-2014, 10:16 AM | #2 |
What's this button do?
Drives: 2019 Black 2SS Join Date: Apr 2013
Good STUFF!
2019 Black & Red & Silver 2SS - Bone Stock
08-01-2014, 10:32 AM | #3 |
Drives: Chevys at the limit Join Date: Nov 2010
Great review and write up, Don! Thanks for taking the time to do this. We truly appreciate your business and support and thanks for choosing JDP and BMR for your suspension upgrades! Let us know if you have any other questions or if there is anything further we can assist you with!
Best regards, Tyler 888-308-6007 |
08-01-2014, 10:45 AM | #4 |
Drives: Race Car Join Date: Sep 2009
Thanks for the positive feedback Don! Glad you are happy with your parts! I'll have to take some measurements on our TCA033's and check that against the outer bushings. Thanks for letting us know.
08-01-2014, 11:28 AM | #5 | |
I've seen this before (I used to make (tig welded) 'arms' for our sprint/midget in the old days) and saw that happen when the metal 'cooled' off the jig. Thank goodness for the hydro spreader! LOVE the quality overall. Really a small thing when you consider everthing I did and how it came out. WOW what a difference and I do mean a difference... Feels like a real sports car with muscle! Tyler was a HUGE help. He had to tolerate my 'idiot' moment and was very patient with my questions. I REALLY like the BMR products -- I also like the Detroit's but the BMR line was in my price range and I felt for what I intended, BMR was the way to go. Since I did this really as a 'one man show', I'm confident others can do this too. Just need tools and 'phone support' and it will work! -Don Last edited by hammdo; 08-10-2014 at 03:22 PM. |
08-01-2014, 12:23 PM | #6 |
Yep, that's probably what it is....but if that's the case we need to widen them up a bit before we weld them then!!! I appreciate your feedback on these, we'll take a look at them. Once again, very glad to hear you are enjoying your new parts!!!
08-01-2014, 12:43 PM | #7 |
Yep, It is THE 'Red Menace' now ;o)
08-01-2014, 12:50 PM | #8 |
Yep, let's get everything tweaked... then it's MY turn!
08-01-2014, 08:44 PM | #9 |
Drives: n/a Join Date: Apr 2014
From the pics it looks like you could just mod the stock rlca's to do the same as the 1le parts
08-01-2014, 08:53 PM | #10 | |
The new lca is good for pre 2012's too. -Don |
09-16-2014, 12:47 PM | #11 |
Awesome thread. Will be wanting to do the same as well! How much did it all run you?
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
09-16-2014, 04:22 PM | #12 |
Depends on what you get. Tyler customized mine based on my needs -- it varies a bit, but the prices are excellent. BMR products are outstanding. Tyler is a huge help with installation.
09-16-2014, 06:27 PM | #13 | ||
09-16-2014, 06:57 PM | #14 |
Sure! Call 'em like it is ;o)
-Don |
