02-17-2015, 03:02 PM | #1 | |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
Can we add auto blip to manual trans?
I've been jealous ever since I've learned the C7 corvette has auto throttle blip feature for the manual trans.
I'm no master of the heal and toe... so I think this feature is pretty awesome. I found that there is at least one company selling an add-on module... was curious if anybody has used it or something similar? http://auto-blip.com/auto-blip here it is installed in a C6 Z06 |
02-17-2015, 03:07 PM | #2 |
Pretty sure not able to retro fit something like this. Would be pretty involved with programming and sensors for the transmission output rpm, current gear, engine rpm, throttle position, engine load, etc....
But, I'm no engineer.
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903 ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me Cortana: 2015 Harley Davidson Road Glide Special V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen Own an Aqua Blue Metallic Camaro? Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros! |
02-17-2015, 03:12 PM | #3 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
The site says it supports the Camaro...
2011 2SS/RS built 8/24/10
02-17-2015, 03:14 PM | #4 |
Drives: '14 RRM 1LT/RS A6 Join Date: Mar 2009
Auto Blip = Rev Matching?
02-17-2015, 03:17 PM | #5 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Interesting....
Good find. I'm curious if this would work on our Gen5 Camaros as well...
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
02-17-2015, 03:19 PM | #6 |
02-17-2015, 03:22 PM | #7 |
Drives: 2010 Camaro SGM 1LT M6 Join Date: Jan 2015
I've been searching for something like this since I got the car.
02-17-2015, 03:44 PM | #8 |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
02-17-2015, 03:56 PM | #9 |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
400 dollars?!?! No thanks
02-17-2015, 04:12 PM | #10 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
Just curious, what is the cost? I read the Camaro piece, and I am confused as to how it adjusts the amount of throttle needed. In other words, depending on speed, you may need more or less throttle for the downshift. if you give too much, the car lunges when you engage the lower gear, and if you don't give enough, you get tremendous engine braking. Neither are good. I have never driven a car with this feature either added or from the factory. I may be making a big deal out of nothing.
PS: I just saw the $395. I agree that seems high, and am still not convinced how it can work well. |
02-17-2015, 04:15 PM | #11 |
Drives: 2012 IOM 2SS/RS 6spd manual Join Date: Aug 2009
What am I missing? I am not seeing what is going on that is different.
I read the link, but why would you want your throttle to open up when you have your brake and clutch pressed? Arent you trying to slow down at that point? Last edited by GMfan454; 02-17-2015 at 04:19 PM. Reason: Read the link |
02-17-2015, 04:16 PM | #12 |
Nissan 370Z comes with this feature doesn't it? Is that the rev matching?
02-17-2015, 04:16 PM | #13 |
02-17-2015, 05:36 PM | #14 |
Night Fury
That guy in the C6 Z06 needs to make his audio stereo.
2014 2LT RS A6
Mods: K&N Intake, Magnaflow Axleback, BMR Strut Tower Brace, VTC Throttle Controller, Tune. |
