AWE Tuning
Old 11-25-2017, 02:27 PM   #1
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
Technical 6 speed manual questions
I searched and I'm sorry if this has been covered, but are the 6 speed manuals on the ZL1s twin disc? Also are the internal transmission gear ratios posted somewhere to 1-6? I know about the 3.73 rear end gears, but just wanted if anyone knew about the other details. Thanks
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 11-25-2017, 02:36 PM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
MJK, Page 5: http://www.camaro6.com/forums/showth...r+ratio&page=5
Twin disc.
LiqTenExp is offline   Reply With Quote
Old 11-25-2017, 05:15 PM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
For what it's worth - ZL1 1LEs are identical to ZL1s in terms of transmission, with one exception: 6th gear was changed from .54:1 to .68:1
Old 11-25-2017, 05:19 PM   #4
Battlezone580
Battlezone580's Avatar
Drives: 2018 ZL1 1LE, 1969 Nova SS 396
Are you sure? First gear is a lot more difficult to engage in the ZL1 1LE vs the ZL1 M6.
18 ZL1 1LE|M6|Nav|PDR|CF Hood|CF WING|CF Dash|Tow Hook|
Battlezone580 is offline   Reply With Quote
Old 11-25-2017, 06:14 PM   #5
Mr. Wyndham
Yes.
Not sure why that is, haven't driving a standard ZL1 M6, myself so I can't speak to that.
Old 11-25-2017, 06:35 PM   #6
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Are you sure?
I havent looked into it, but when the ZL1's were first introduced in 17 they touted that the manual cars would hit 60 in 1st gear, but im not getting that out of my car.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 11-25-2017, 06:55 PM   #7
Mr. Wyndham
Originally Posted by nighttowl View Post
Are you sure?
Because your wheel/tire ratio is smaller. The overall effective ratio is reduced by about 2%, but first gear is still 2.29:1. I'll double check, but I'm 99.99% sure only 6th gear was changed.
EDIT: All I've found so far is a note in the press release that the car has a "6 speed manual tarnsmission standard (with a 1LE-specific top gear ratio)".
Old 11-25-2017, 08:29 PM   #8
nighttowl
nighttowl's Avatar
I didnt think about that; that would most likely make the difference I am seeing, its about a 5 mph difference.
Old 11-25-2017, 08:35 PM   #9
Mr. Wyndham
same here
Old 11-25-2017, 08:39 PM   #10
Dwille
Drives: 2022 SS 1LE
Twin disc! Cool. Mine hits 60-61 right at the rev limiter in 1st. From PDR video at a local autocross. Speed was corroborated by my data recorder.
Dwille is offline   Reply With Quote
