Old 07-16-2010, 07:56 PM   #1
Jram1588
Jram1588's Avatar
Drives: 2010 VR Camaro / 2007 GSXR
Question about tire sizes
I have a question regarding tire sizes. I've read threads about recommended tire sizes etc but my question is this. What does each number represent? Might sound like a dumb question, if it is I'm sorry just didn't know. Also I'm looking for a thin low profile tire, I don't like the thicker sized stock tires I have now so I want to wrap my new rims in a thinner tire. What size would you recommend? Thanks.
Jram1588 is offline   Reply With Quote
Old 07-16-2010, 08:13 PM   #2
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
I had 22 and went to the 18s you have now. BF goodrich puts out a higher speed rating tire than the OEM you are driving now in the same size, P245/55R18 all-season. Best move I ever made the ride is better and the performance is also great on the strip. Think about it, when was the last time you saw a low profile tire on a this type of race car. Many reason why a larger profile tire is better.
Most just think the low profile looks better.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 07-16-2010, 08:21 PM   #3
Jram1588
Jram1588's Avatar
Low profile is better for a show car. I don't take this one to the track it's all cosmetic upgrades. But I'll keep that advice in mind for when I get my track car, thanks!
Old 07-16-2010, 08:57 PM   #4
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
First decide how big rims you are looking for. 24? 22? 20? Then you look for your tires. 245/55/R18 means 245 Width of the Tire, 55% of it is Profile (on both sides, front and back) and 18" inch rims.
So for example, maybe you want 275/40/R20... usually for the rears for 20". So 275 Width, only 40% of 275 is profile, and Rim 20s.
Do you kind of understand the numbers now? for 20" fronts, its mostly 245/45/R20.
jagan323 is offline   Reply With Quote
Old 07-16-2010, 09:09 PM   #5
Jram1588
Jram1588's Avatar
Ah ok perfect thanks that was really helpful. Now does the greater percentage mean the thinner the tire? or is it the opposite? And I'm going with 22s
Old 07-16-2010, 09:26 PM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
The lower the percentage is the thinner the tire, As long as the Width is the same. ie 275/40/20 is a bigger tire then a 275/30/20
2SSRS@Gen5diy is offline   Reply With Quote
Old 07-16-2010, 09:41 PM   #7
Jram1588
Jram1588's Avatar
Ok cool thanks alot for the help I appreciate it.
Old 07-16-2010, 11:30 PM   #8
jagan323
I have no life
jagan323's Avatar
NP =) post some pics when u get ur new Shoes
Old 07-17-2010, 05:30 AM   #9
monstertodd
monstertodd's Avatar
Drives: 2010 Cyber Grey Metallic 2SS/RS M6
Helpful info!
monstertodd is offline   Reply With Quote
Old 07-17-2010, 07:27 AM   #10
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Your 22s will have a thinner tire for sure. What is important is that the outer diameter (height) of the tire remains similar to the factory tires. As wheel diameter increases (20" up to 22") your tire sidewall simply reduces in thickness. The 20" and 22" tires themselves should be about the same height though. Shoot for a max of 1/2-inch difference in height. Otherwise, your speedometer, automatic trans shift points, Anti-Lock braking system, traction control, etc... will be thrown off.
Fquick.com/NineBall
Nine Ball is offline   Reply With Quote
Recommended Tire Sizes for 2010 Camaro Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 367 04-23-2024 11:22 AM
Tire sizes 2nd gen Milk 1027 1st & 2nd Generation Camaros 12 09-08-2014 01:04 PM
Question about a tire size. GuidosCamaroSS Wheels and Tires Talk Sponsored by The Tire Rack 11 07-03-2010 05:46 PM
Lets start a Tire Specific Thread here, sizes, brands, specs and other usefull info. 55Designs Wheels and Tires Talk Sponsored by The Tire Rack 0 12-20-2009 07:58 PM
LS tire sizes for winter thaone151 Wheels and Tires Talk Sponsored by The Tire Rack 2 11-14-2009 07:18 PM
