06-14-2013, 08:03 PM | #1 |
Drives: 2011 2SS Join Date: Jun 2013
fuse pull/good with custom tune?? 2 questions
So my car has been dyno tuned and I was wondering after reading 15 pages on the fuse pull thread should I do this I have an LS3 is is tuned for 91 octane is what I am told. The tunner said he would rather me run 91 then take a chance with the 93 fuels around here that could be really old and no good. So since it was tuned is it necessary to do this mod/hack and will it hurt anything to do this(like lose my custom tune)? I have never ran anything other than 91 and I am wondering if I should try 93, will upping the octane hurt since I am tuned for 91?
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
06-14-2013, 08:10 PM | #2 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
Yes it is still necessary, no it will not hurt your car.
06-14-2013, 08:25 PM | #3 |
Drives: 2010 2SSRS headers/CAI/tune/corsa, Join Date: May 2010
I was told with tune fuse pull not needed . Will not retard.
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 ) JL Audio XD400/4 amp Pfadt trailing arms & tie rods sway bars. pedders street 1 package. ,Hurst short throw shifter With bronze bushings . |
06-14-2013, 08:36 PM | #4 |
Only way that's true is if your tuner copied the high octane table to the low one - in which case you better pray someone never puts low octane fuel in the car.
06-14-2013, 08:38 PM | #5 |
by retard you mean running the 93 will not retard the timing. Or are you calling me a retard lol
06-14-2013, 08:40 PM | #6 |
He's saying that the car won't pull timing if you put 87 in it.
06-14-2013, 08:42 PM | #7 | |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
06-14-2013, 08:42 PM | #8 |
Stig thats why I was wondering when I had my gears put in I have a feeling the guy out a couple gallons of cheap fuel in it when he had the car. CARFX of Tulsa tunned it I am not sure how he did the table I can probably find out but still trying to decide if I should do the pull and start running 93
06-14-2013, 08:55 PM | #9 |
Geek
Pulling fuses with a tune will still reset your long term fuel trims. It could be useful in certain circumstances, but not yours.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
06-19-2013, 06:11 AM | #10 |
? On my Livernois did they use two tables high and low .
must find out.......Andy?
06-19-2013, 06:50 AM | #11 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Depends if your 2 tables are the same or not. My high octane table is tuned for 93 octane. Still have the low octane table, which it will revert to for bad or lower octane gas.
06-19-2013, 06:51 AM | #12 |
Most reputable tuners won't copy the high octane table down to the low one as it can do serious engine damage if you put low octane fuel in the car.
06-19-2013, 06:57 AM | #13 |
I have wondered this exact thing for a while now but never asked. Now I'm curious if it would matter with my JRE tune.
06-19-2013, 07:18 AM | #14 |
GrINned & JUICEd
I was told by JRE that they do not mess with the low octane table. So 2 tables. Yours may be different though???????
