01-31-2024, 10:11 AM | #1 | |
Drives: 2014 M6 ZL1 Join Date: Jan 2012
9 sec M6 passes at CA24
New combo after lifting a head gasket last year at Cadillac Attack (CA23).
First full passes in 1600-2000 DA on new build. 4280 lbs tech weigh in with driver. Jake Hartline built 427 RHS, Kong 2650, Meth, E85. Fore dual with ID1700 injectors. RPM Level 6 TR6060, new Monster Triple, Menscer front and rear coil overs on street settings for now. New motor and driveline installed by Fat Body Performance. Tuned by Cal Hartline https://www.youtube.com/shorts/pGZkrk2KGz0 https://www.youtube.com/shorts/AFQ4-JVX6UI
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH 12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD 06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD. 96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH Last edited by 2NASSTY; 02-02-2024 at 12:22 AM. |
01-31-2024, 11:06 AM | #2 |
That's a really nice run!! Camaro looks great as well!! Cal also did the tuning on my Camaro, really great guy, and knows his stuff!!
01-31-2024, 06:18 PM | #3 |
that's a great number. can you imagine if you cut that 60' to a 1.4S or so.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
01-31-2024, 06:57 PM | #4 | |
I agree! I believe that will happen with the Menscers. The 1.50 was the best sixty I've ever had so far in this Car.
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH 12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD 06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD. 96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH Last edited by 2NASSTY; 02-19-2024 at 08:42 AM. |
02-01-2024, 04:29 PM | #5 |
Drives: 2013 ZL1 Join Date: Sep 2021
Time to modify your signature.
02-01-2024, 06:55 PM | #6 |
Very nice! Is there a roll bar requirement?
Also what tire pressure were you running without beadlocks?
02-02-2024, 12:32 AM | #7 |
Thanks Man. Typically there is on the roll bar and parachute @ 150 mph. I’m almost there. 18 lbs hot on tire pressure. I use glue instead of beadlocks. Not much tire to wheel spin.
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH 12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD 06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD. 96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH |
02-04-2024, 08:54 PM | #8 |
Drives: 2014 ZL1 Join Date: Jun 2009
Baddass! Congrats!
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
02-05-2024, 05:59 AM | #9 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Sweet pass, that's moving on. What's your goal for the car?
02-05-2024, 02:22 PM | #10 |
Thanks Man! Appreciate it.
Thank you. That's a great question! The Car literally just became streetable weeks before this meet. 1-year grueling build. Driver (me) was not ready either, being out of the Car for a year and then adding 250-300 rwh. The 9.7 pass was the 2nd full 1/4-mile pass and was #1 Qualifier in a strong Manual class. I ran 3 more 9s then lost in the finals on that 9.8 slip to the left. Most of the goals of the Car were met at the meet. It's probably a 9.4 - 9.5 Car with a 1.4 sixty, better air, and NLS 1-2. I didn't want to do that yet in a big meet where you have to go rounds and not break your shit. I'm also tired or pouring $$ into this thing also. Rant over. Did not expect to go this fast or quick right out the gate. Extremely Happy!
02-05-2024, 02:48 PM | #11 | |
02-05-2024, 05:33 PM | #12 |
Thanks Man! I had a lot help with this build. Just want to enjoy it now. Not all at the track either.
02-05-2024, 05:37 PM | #13 | |
Congratulations on the excellent results. Quite the accomplishment!
02-05-2024, 09:56 PM | #14 |
Thank you! I'll be honest it was scary as hell on the street on the 20" factory rims on Nitto Extremes. Not a good tire combo with 1100 rwh. The solid engine mount bmr bushings, Big ass cam for a manual thru 3" Corsas and no traction was not comfortable and rowdy as hell. People would look at me at a stop like I must have lost my damn mind!
I learned how to feather the throttle at all times. That all changed with the track tire set-up and Menscer shock adjustment. Car actually felt mild and stable with traction.
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH 12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD 06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD. 96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH Last edited by 2NASSTY; 02-17-2024 at 09:17 PM. |
