Vararam
Old 12-13-2023, 01:41 PM   #1
Mr Notorious
Drives: 2011 SS - SOLD
Ported Blower on Stock Tune?
Hey guys, 35k mile car, M6 totally stock except a 2.9 upper pulley. I had a guy replace the snout bearings replaced and solid isolator installed using the eaton stuff from SCOL.
My blower is still rattling after all this with pretty much the same noise, so I'm leaning towards sending it out to Jokerz performance for a rebuild but I see there is a decent discount to have the rebuild and budget port job done at the same time.
Does anyone have any experience with having a ported blower, on a stock car, while running the stock tune?
If the car goes into a lean scenario, will a CEL appear and/or will the tune self correct (ie timing) to ensure no damage is done?
I do road course the car quite a bit, so it will see WOT.
Mr Notorious is offline   Reply With Quote
Old 12-14-2023, 12:17 AM   #2
MontanaFlyFisher
MontanaFlyFisher's Avatar
Drives: 2013 ZL1
I would advise against running a ported blower on a stock tune, especially because you are already up against the limits of the stock tune with the 2.9” pulley. Don’t risk your engine over saving a few hundred bucks.
2013 ZL1 Inferno Orange, 6MT, no sunroof, chromed 5 spokes, hydrodipped moldings, CAI intake, 7K miles.
1967 Camaro RS - Home built pro-tour build w/ LS swap - GONE
1967 Bronco - first ever documented EB w/ LS swap - GONE
2004 CTSV - GONE
2002 Z28 - GONE
MontanaFlyFisher is offline   Reply With Quote
Old 12-14-2023, 08:26 AM   #3
Dark Sun
Dark Sun's Avatar
Drives: 2014 Camaro ZL1
I raised my boost about 3 psi on the stock tune without issues. No pulleys or tuning. Car is a completely different animal now. Boost at 1500 rpms, breaks traction at 60 mph. From my experience, porting will help airflow yes, but the MAF sensor still measures the total amount of air and that’s what the ECM reads.
Dark Sun is offline   Reply With Quote
Old 12-14-2023, 05:53 PM   #4
Little Walter
Drives: ZL1
I would highly recommend checking the AFR if nothing else, some cars actually run richer with a ported blower, ported heads, cam and exhaust due to being more efficient requiring less fuel and then some will run leaner which is what you do not want. I would not take the risk to save less than a $1000.00 bucks. Detonation (lean) cost dearly.
Little Walter is offline   Reply With Quote
Old 12-26-2023, 07:04 PM   #5
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
This topic has been debated on many times, short answer is to be safe you should tune it...
Now I will say that I had a Roto-fab CAI, 2.83 upper, ported LS3 TB, SC inlet and Housing, SLP headers .
That was all on a stock tune and it ran very well.. was I pushing it , probably but it hauled ass !!!
2012 ZL1 preproduction car #13
ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet
JBZL1 is offline   Reply With Quote
Old 01-02-2024, 11:17 AM   #6
Shodown
Shodown's Avatar
Drives: 2014 ZL1
I bet you believe in direct exhaust injection too.
OP,
Get your car tuned if you port the blower.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
Shodown is offline   Reply With Quote
Old 01-02-2024, 12:23 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hell, my SS breaks traction at 60 mph!! lol. If you do a pulley swap, always good to re-tune the car so that the ECU is calibrated correctly for the extra boost to keep the AFR's in check. Just seems to reason... All my friends with ZL1's did when they did a pulley swap..
Old 01-13-2024, 04:39 PM   #8
TopDawg_43
One of the early mods in my build was a pulley (2.55"). When I got it tuned, I was informed I had to go with bigger injectors. I was running out of injectors at higher rpms. We had to set the rev limiter at 6k. At that time, I only had a RotoFab and Kooks Long Tubes to go along with the pulley.
Staying with a stock would have been costly, given the way I drive my car.
So either tune it or drive it slow.
My vote: Tune it and go have fun.
TopDawg_43 is offline   Reply With Quote
