Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 05-20-2009, 10:52 AM   #1
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
3rd Gen Camaro Street Stock build thread (dialup beware)
I'm a newb to Camaros and this forum, but not to wrenching and bulletin boards in general. My friend Nick and I are currently building a 3rd gen Camaro street stock, I thought I would see what you guys think about it...
Late last Fall, my buddy Nick came by and informed me that he wanted me to go with him to look at a Camaro he saw on craigslist. He said it didn’t have an engine or tranny, but it was only $100 and had a “clean title”. We drove out to the address on the listing and checked it out. Instead of being a car minus an engine and tranny, it turned out to be a shell. It had no interior except for an unbolted driver seat, no engine, no tranny, no wheels and tires, resting on a tree stump and some cinder blocks in an overgrown barnyard, beat up hood laying in the weeds, etc, etc. I tried to talk him out of buying it and I thought that I had succeeded, because he was convinced that it needed more work than he wanted to do to become streetable. Since we didn’t bring a trailer anyway, we left and he spent the night thinking it over. The next day he informed me that he was going to buy it and build a street stock, so we grabbed his trailer, swung by the junkyard to get some wheels tires,and lugnuts, then went and retrieved one slightly used 1984 Camaro.
First off, let me tell you something about us. Nick owns the car and will be driving it. My name is Zane. I am donating labor to help him get racing. I am a mechanic, not a “race car guy”, but I can fabricate. Nick has been around racing much more than me, and actually has pretty good contacts around town. He has crewed (donated labor) on some pretty high dollar (locally speaking) race teams and done a lot of travelling to races here in the west. He has never driven though, so this will be a first for him. We will be racing locally, at Meridian Speedway. It is a ¼ mile flat paved oval. We will be racing in the “Street Stock” class. Street stock is the basic “run what you brung” kind of class with a lot of restrictions in place to keep it affordably competitive. For instance, you must run stock type cast iron intakes, and cast iron exhaust manifolds. The class carburetor is a Holley 4412, 2 bbl, 500 cfm. Suspension must remain in stock configuration (leaf spring cars must remain leaf spring cars, etc.), but you can buy racing shocks and springs. A lot of the cars are full frame cars, but several guys are running 2nd gen Camaros. I believe we will be the first here locally to run a 3rd gen Camaro, because the rules just changed this year allowing cars with 101” wheelbase to compete.
The car originally had the four cylinder engine with a 5 speed, but later had been being run with a SBC and an THM tranny according to the seller. There wasn’t an engine and tranny in it anyway, so the only thing that mattered to us was the fact that it still had the clutch pedal, since Nick wants to run a manual tranny. Nick already had a good 350 four bolt main engine from an earlier project, so we have the power plant covered, it just needed to be freshened up with new rings and bearings.
Upon getting it home, we knew we would have to work fast to make racing season, so we very promptly parked it in his garage and closed the door. Then we forgot about it for a couple of months and did absolutely nothing to it. Nick was finishing up welding classes at the local university, and didn’t have much time for anything else, including a job, which meant that he had no money to buy materials for the car. After seasoning the car well in the garage for weeks on end, we finally decided to get to work on it. Nick was able to get us a couple of sponsors. One of the sponsors is a fabrication shop owned by Nick’s buddy Mark and the other being a junk yard up the street from his house. We would build the roll cage and do other fab work in Mark’s shop, and a lot of the stuff we needed to get the car going would be free from the junkyard.
So the game plan is to build the car to the following basic specs:
350 four bolt main (I’ll update with the particulars later)
3 speed Sagina tranny with dual stick shifter mated to a metric bellhousing
Stock rear diff w/ 3.73 gear ratio and a “Lincoln locker”
1 ¾” x .120” HREW tubing roll cage
8 gallon fuel cell
2” schedule 40 black pipe front bumper / 2”x3”x ¼” rectangular tube rear bumper
Quick release steering wheel hub w/ 15” steering wheel running P/S
Kirkey Racing seat
Simpson 5 point harness
Hoosier 970 series racing tires
5/8” extra long quick start wheel studs
Suspension is still up in the air, we will go as far as our limited budget will allow
We started by stripping all the crap that was still in the car out of it. Having no interior saved us a lot of trouble, but we did remove all of the glass, the dash, the heater assembly and all the duct work. We removed the doors and took the torch to them until they were reduced to just the exterior panels. We removed the headlights, taillights, and all of the other plastic crap. We removed all of the wiring, ecu and related useless crap. Nick got a job so he bought enough tubing to start the roll cage. We took the car over to Mark’s shop and started on the cage. Nick bought a few sticks of 1 ¾” .120 wall HREW and got busy on the cage. First we installed the main hoop and halo. Then we bent up some A pillars and welded them in. Then we made the rear support tubes for the main hoop and welded them in.
The cage is being tied into the floor pan using 1/8” plates.
We tried to tie it in on top of or as close to the box portions of the front & rear sub frame as possible.
zlathim is offline   Reply With Quote
Old 05-20-2009, 10:55 AM   #2
zlathim
zlathim's Avatar
After adding some door bars, it began to look like a race car, at least on the inside. We hacked out the steering column and fabbed up a bracket with a heim that comes off of the dash bar of the cage to support the steering shaft.
Nick attached to seat back to the cage and made a steel frame for the bottom that also ties into the cage.
Nick reinforced the rear sub frame area with 2x3x1/4” rectangular tubing and installed the new steel can fuel cell.
The front struts on this car present a challenge. All the other cars in our class are double a arm suspensions. Everyone runs with no inner fenders, because they are in the way and just end up getting beat up anyway. On our car, the inner fender is the anchor point for the strut tower. If it gets bent up, our steering geometry will be screwed. We are in the process of trying to tie the strut tower into the front hoop of the roll cage. If we can do that, the inner fenders are going to get chopped out.
Nick built and installed a 2” schedule 40 front bumper and rectangular steel rear bumper (not pictured). Both of them tuck under the factory bumper cover. The firewall has been sealed off using 18 gauge sheet metal.
The entire rear of this car was a big a$$ heavy piece of glass, that when removed leaves a cavernous opening. We had to extend the rear firewall up with some sheet metal to seal the fuel cell from the driver area. You can see what that looks like in one of the photos above. Nick has a start on the new deck lid. He has the basic shape cut out and broke on the edges. It needs some work before it will look good, but it is started. Since all of the glass and plastic has been removed, it is necessary to cover the headlight and taillight areas with sheet metal. Nick has completed the rear light cover and it looks pretty good.
Old 05-20-2009, 10:59 AM   #3
zlathim
zlathim's Avatar
Nick bought new rotors, so we installed the 5/8” long wheel studs in them. We had to pound out the stock studs and drill the holes out bigger to accept the larger diameter studs. We got the tires mounted up on some new 15x8” racing wheels with 3” backspacing.
We had to remove the rear axles in order to drill them for the larger studs. In order to make sure our holes are dead center on the existing smaller holes, we chucked up a transfer punch that was the same size as the existing holes and then we lined it up and clamped it down:
Here is a comparison shot of the old studs and the new larger variety. Sorry about the blurry pic, but you get the idea:
For the engine, Nick had a four bolt main 350 that came out of a step side pickup his dad got in a trade. He tore it down, and the thing was actually in pretty good shape. It has .030 over TRW pistons and an Iscanderian cam in it. There was very little wear on the engine, so we decided to throw a set of rings and bearings at it and call it good. It also got a new oil pump, water pump, and a seven quart claimer style oil pan. We got a cast iron 2 bbl intake from the junkyard and also got some exhaust manifolds. We do not yet have the carburetor. We need a Holley 4412 for this class. We also need to grab an early HEI dizzy for it. Here is a picture of it tore down.
Here is the cam that is in it:
Here it is all assembled and ready for mock up:
Nick picked up a used Sagina tranny for $50 off of craigslist. Since the car has the clutch pedal assy in it, we want to use the stock style hydraulic clutch system for this race car. In order to avoid fabbing a slave cylinder bracket, we decided to use a metric bellhousing with the bracket on it. The bolt holes on the tranny and bellhousing lined up, but the bearing support / front cover on the tranny was to big to fit in the hole on the bellhousing. I unbolted the bearing housing and chucked it up in the lathe to turn it down so that it fit into the bore on the bellhousing. That seemed to do the trick. Nicks dad bought him a twin stick shifter with funky purple shift rods, so we have some bling to bolt on. Yes, I know we have the shifter handles facing the wrong way in this photo:
Here is a view of that front bearing support we had to turn down in the lathe in order to get the bellhousing to fit:
We still have a lot of work to do. Probably at least 80 hours worth of work needs to be done. That is just to get it on the track. Tuning and setting up the suspension is a whole ‘nother story. For the street stock class, the first race is tomorrow night. We obviously won’t make that race or any other race in May for that matter. We are hoping to have it ready to race in June.
If there are any questions or constructive criticism, I would love to hear it., Otherwise, stay tuned because there will be more to come.
Old 05-21-2009, 08:20 PM   #4
Supercamaro64
Right, right.
Supercamaro64's Avatar
Drives: 79 Z28, 86 Camaro, 94 Burb 4x4
sweet man! let us kno wen its done!
"You wanna lay the fate of the world on the kids camaro? Thats cool."
"When reporters asked what it was, one official stated, 'It's a small, vicious animal that eats Mustangs.'"
The Creampuff Fleet-
Supercamaro64 is offline   Reply With Quote
Old 05-21-2009, 11:53 PM   #5
ksmarshall
Drives: 1992 camaro RS
i love the work you all are doing everything looks great , cant wait to here more
ksmarshall is offline   Reply With Quote
Old 05-12-2011, 04:11 PM   #6
ericprice55
ericprice55's Avatar
Drives: 1978/2011 camaro
I know this is an old thread, but did you guys ever finish?? Come check out the street stock ive been putting together....
ericprice55 is offline   Reply With Quote
Old 05-12-2011, 10:37 PM   #7
drknow90rs
drknow90rs's Avatar
Drives: '90 RS 427ci LS-1, '86 IROC 305 TPI
Yeah, I remember this thread from TGO around the same time...
drknow90rs is offline   Reply With Quote
Old 02-19-2013, 11:04 PM   #8
Wayne36
Drives: 3rd Gen Camaro Dirt Track car
Did you ever finish it? how did it do?My daughter is running a 3rd gen also this year, did you have any issues?
Wayne36 is offline   Reply With Quote
Old 09-28-2018, 07:20 PM   #9
zlathim
zlathim's Avatar
Hey guys. I had forgotten all about this thread. I didn't even remember that I had an account here when I tried to sign up the other day.
So here is your timely update (hey its only been a shade under a decade...).
We did finish the car. It ran pretty good and Nick raced it for 2 seasons before selling it. He won a few heat races and finished as high as second in some main events. I hear that the car is still around, but I haven't been to the circle track races in years.
The biggest issue with the car at first was overheating. The e-fans weren't optimal. The second issue was our upper strut mounts. They were terribly engineered and ended up bending the tops of the strut shafts. They did, however last for 2 seasons of racing, so they must not have been too bad.
Now I'm on to bigger and better things. I just got this pile and I'm gonna turn it into a street/strip menace:
Old 12-06-2018, 10:30 AM   #10
zlathim
zlathim's Avatar
I started this thread and some other threads on other sites. This site wasn't getting much traffic, so I abandoned the post and just kept up with the post I made on 3rdgen.org because there was actually some interest in the project. To atone for abandoning this post, I found some old pics of the car after it was finished and had been raced a while:
It was a fun project, but I'm really not very interested in circle track racing. Loved building the car, hated taking it to the races.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
Camaro Product Manager - interview Moose 5th Gen Camaro SS LS LT General Discussions 11 04-04-2012 06:10 PM
GM memo to dealers Moose 5th Gen Camaro SS LS LT General Discussions 41 02-04-2010 07:33 PM
I'm not sure if I'll buy a 5th Gen. Camaro Moose 5th Gen Camaro SS LS LT General Discussions 68 06-13-2009 05:18 PM
Q&A with fbodfather (Scott Settlemire) regarding upcoming Camaro JustinZS 5th Gen Camaro SS LS LT General Discussions 22 05-20-2008 07:48 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
