TireRack
Old 10-06-2012, 07:12 PM   #1
motor389
Drives: 642 HP Supercharged 2010 RS/SS
Whipple tune?
Hey ,all ,Monday I'm having the car tuned ,with all everyone has done to there cars any advise you can pass on to me ? Whipple 2.9 , long tube headers 17/8 high flow cats, CAI .thanks Motor
motor389 is offline   Reply With Quote
Old 10-06-2012, 07:55 PM   #2
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
Gut your cats before you tune it. You'll melt the inside of them and it will be much more difficult to do later.
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 10-07-2012, 12:53 AM   #3
dookie454
Drives: 2010 Camaro 2SS LS3
I just put a whipple kit on my stock 2010 6 manual. As stock, with the stock tune, things seem lean, mostly due to the injector data. I would give you my data, but it's all hacked up. It was by default, about 8% lean.
So dont go flooring it too much until you get a WB tune.
And anybody else notice the Whipple MSD Fuel Pump Booster causes alot of radio interference?
dookie454 is offline   Reply With Quote
Old 10-08-2012, 05:46 PM   #4
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
The Whipple tune is intended for a stock airbox and if you are 100% stock with the blower it works pretty good. Fueling is rich and safe and you should not have any issues unless you modify the car. Injector data is 100% accurate
Meister@Torq is offline   Reply With Quote
Old 10-25-2012, 10:29 PM   #5
dookie454
How about the IAT cal? Mine (and other people) are noticing iat's are always about 15F below ambient/actual temp. The coolant temp and ambient air temp ( on radio) are correct and the IAT temps are 15f low on a non-running, 24+ hr off, parked in a garage, constant temp environment... Seen it at 50f ambient through 80f so far, stock whipple tune.
Old 10-26-2012, 07:25 AM   #6
usmcjlp
Drives: 2SS/RS LS3 RJT
The Whipple MSD Fuel Pump Booster Does cause a lot of radio interference. As soon as I installed this kit my radio was useless.
usmcjlp is offline   Reply With Quote
Old 10-26-2012, 10:00 AM   #7
Motion427
Drives: 2010 2SS/RS Red Jewel L99
At Whipped416 level.I think he's at 850RWHP.I don't think the ZL1 pump will be enough.
But at 500-650RWHP level the ZL1 seems to work well.
Motion427 is offline   Reply With Quote
