Old 04-25-2024, 06:50 AM   #1
Davescamaro
Drives: Chevy camaro
Ignition parts
Hi all,
Well it's that time of mileage to change out the spark plugs. I know on turbocharged engines you can go 1 step colder to help out on the turbo. Any recommendations? I see the ac Delco iridiums and that's OE. NGK offers an iridium as well. Wanted to pair it with the zzp ignition coils. Thoughts or help?
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears.
Davescamaro is offline   Reply With Quote
Old 04-26-2024, 11:14 AM   #2
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
I'm not sure about the spark plugs. My tuner said the stock OEM ones were prefect. We did not go a step colder. Also, DO NOT BUY ZZP COILS. They are garbage. Just paint the stock ones red if you can't resist the urge. Like the OEM spark plugs, the OEM coils are the best option. Do not mess with them.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 04-26-2024, 04:51 PM   #3
Davescamaro
Thank you. I'll just get the ac Delco iridium plugs. Keep the coils until they start to not work. Didn't know that zzp coils were junk, they said the MSD coils foul up after a little while.
Old 04-29-2024, 11:37 AM   #4
Start The Machine
I stand corrected. I was thinking of the MSD coils. I haven't heard anything bad about the ZZP Coils. Just the MSD ones.
Old 05-03-2024, 11:26 PM   #5
SS_AL
SS_AL's Avatar
Drives: 2017 Camaro RS l4 turbo
I use Denso Iridium, 1 step colder, with E-85, works like a charm, ZZP has them, they're rated for boosted/high performance applications
SS_AL is offline   Reply With Quote
