dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > ZL1 Engine, Exhaust, and Bolt-Ons
Old 03-06-2015, 08:25 PM   #1
Juiced1
Drives: 2012 2SS CAMARO 45th
METCO LSA INTERCHANGEABLE CRANK PULLEY KIT IN STOCK @JUICEDMOTORSPORTS
This crank pulley kit is based on the Innovator's West replacement balancer assembly for the GM LSA engine. This kit represents a clean and simple way to add boost and horsepower to your supercharged Cadillac or Camaro without making any permanent modifications.
The Innovator's West balancer is precision-machined in the USA and installs directly in place of the factory unit. The IW balancer and crank ring assembly weighs only 12.6 lbs, compared to 16.2 lbs for the factory steel unit. Installation of this kit removes significant rotating mass from the front of the engine.
Our CNC-machined crank pulley rings bolt directly to the new balancer using the provided fasteners. Once the balancer assembly is installed, changing the outer ring to adjust the boost level is simply a matter of six the allen-head fasteners. Crank pulley rings are also available separately and are listed elsewhere in this section.
We installed the IW balancer, 9.55" crank pulley ring, and 50mm idler pulley on our own CTS-V. On ProDyno's chassis dyno, the car made 547 HP at the tires, right off the street, with a very safe tune. The car showed a max boost level of 13.5 lbs (13.9 indicated on the dash gauge).
Note: The 9.10" and the 9.55" crank pulley rings require the use of the Metco reduced diameter idler pulley
The 10.00" & 10.50" crank pulleys require the use of the Metco crank idler pulley relocation bracket (with the 50mm idler pulley)
Supercharger Belt Lengths:
+2 lbs 8.60" Crank pulley ring and stock idler pulley: 67.5" belt
+3 lbs 9.10: Crank pulley ring and 50mm idler pulley: 68.0" belt
+4.5 lbs 9.55" Crank pulley ring and 50mm idler pulley: 69.0" belt
+5.5 lbs 10.00" Crank pulley ring with 50mm idler pulley and idler relocation bracket: 71.5" belt
+6.5 lbs 10.50" Crank pulley ring with 50mm idler pulley and idler relocation bracket: 72.5" belt (estimated)
Note 1: The original belt in most applications is 66.0" in length.
Starting at $719.95 shipped
Old 03-12-2015, 01:55 PM   #2
Juiced1
Installs easier then a blower pulley and helps reduce belt slippage.
Old 03-19-2015, 08:22 AM   #3
Juiced1
In stock and ready to add boost!
Old 03-26-2015, 09:49 AM   #4
Juiced1
Don't let these GT500 and Hellcats own your ZL1. A few mods like this one will put them where they belong!
Old 04-01-2015, 09:52 AM   #5
Juiced1
Your ZL1 isn't slow but it can use some extra boost. Metco pulleys are a great option and Juiced has them with free shipping!
Old 04-09-2015, 12:52 PM   #6
Juiced1
EZ BOOST
Old 04-15-2015, 09:46 AM   #7
Juiced1
Pulley that crank and you will add easy boost while helping eliminate belt slip.
Old 04-23-2015, 08:36 AM   #8
Juiced1
Boost up
Old 04-28-2015, 09:21 AM   #9
Juiced1
Crank pulleys offer more boost with less belt slippage.
Old 05-06-2015, 09:41 AM   #10
Juiced1
ez boost
Old 05-11-2015, 09:04 AM   #11
Juiced1
This is how you make serious boost without belt slippage.
Old 05-22-2015, 08:12 AM   #12
Juiced1
PULLEY UP
Old 05-31-2015, 10:29 PM   #13
Juiced1
Pulley up
Old 06-07-2015, 10:47 PM   #14
Juiced1
Boost up
crank pulley, lsa pulley, metco
